daves16v
Lifting with Trolley Jack
Where are the best lifting points front and rear on a Corrado when using a trolley jack?
Photo's would be handy.
Cheers
Lifting point is at the rear of the front wheel arch... there's a small pressed arrow on mine showing the exact point (which is just past the line of the door). If you're using a trolley jack you coudl do what I've done and get a block of would with a cut in groove so as not to risk damaging the paint / lip.
When using the jack point this lifts the whole side of the car so they dont have a rear one marked on the sill 8)
at the front, put it under the subframe, where the anti roll bar goes through.
at the rear, put it on the rear axle pivot, or immediatelty in front of it.
DON'T EVER JACK ON THE SILLS OR THE FLOORPAN. you'll bend it and scrape off the underseal.
Am I to assume axle stands should be placed under the subframe too. I'm changing my brakes tomorrow so any help is greatly received.
Cheers
I hate jacking up my rado. I got a trolley, any pic would be brilliant :grin:
AGREED :notworthy: :clap:
Anybody got some pics? Would be usefull reference.
Wary these days after previously using a jacking point & discovering rust problems with a loud BANG & soiled underpants. :shock:
boost monkey put up a pic in another thread like this a while ago but i can't find the thread for now.. its still there somewhere though!
