JimVR6 10 Posted November 2, 2012 Does anybody know why my instrument panel is really dim at night? The little brightness wheel is turned all the way up and I can see the computer/clock just fine. I just can't see the speedo or rev counter, both work but very dim. Quote Share this post Link to post Share on other sites
MarkFoster 0 Posted November 2, 2012 It's a design feature, lol! People get round it by going for the DDI or spoonfed dials which are backlit. I myself get over the problem entirely by simply not driving the car at night! M. Quote Share this post Link to post Share on other sites
JimVR6 10 Posted November 2, 2012 Well the not driving at night thing is pretty much an impossibility for me but I will look into alternate dials. It's not really bad but just annoying. Quote Share this post Link to post Share on other sites
davidwort 0 Posted November 2, 2012 the bulbs do blacken with time, I'd put some new ones in. Quote Share this post Link to post Share on other sites
JimVR6 10 Posted November 2, 2012 Do you know what kind of bulbs they are? Jim Quote Share this post Link to post Share on other sites
dragon green 6 Posted November 2, 2012 The new ones have blue bases,(old ones were green) the blue ones don't omit as much light as the green ones ! http://the-corrado.net/showthread.php?46064-How-to-change-blub-in-instrumental-panel Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted November 2, 2012 Get them from VW. Not cheap though! Quote Share this post Link to post Share on other sites
Corradochris16v 10 Posted November 3, 2012 Am sure there's someone on here that can convert the bulbs to led so there a lot brighter and can have pretty much any colour you want Quote Share this post Link to post Share on other sites
tony_ack 0 Posted November 6, 2012 I had this... I fitted the wrong bulbs. The ones behind the clock/computer are 12v 1.1w/1.2w The three above the dials are 12v 1.8w I had fitted 1.2w bulbs throughout and the dials were really dim. Picked up some 1.8w bulbs from veedubmachine (VW were too pricey) and they're bright again now. Quote Share this post Link to post Share on other sites
fla 9 Posted November 6, 2012 leds wont work unless you have 3 per dial of the SMDs. If not, just get bulb replacements from Maplins. Quote Share this post Link to post Share on other sites
5dOt1 0 Posted November 6, 2012 Hmm, I think you will need one of this: Never to dim :D Four 0805-SMD LED per dail (12 in sum), full dim-able. Feasible in bright, brighter or extra bright :D Special fitted to our VDO Corrado clusters. The same for the LCDs: Quote Share this post Link to post Share on other sites
robrado974 1 Posted November 14, 2012 Just got mine back on the road and noticed my dash is dim , im positive it was never like it before , i changed mine from green to red with the stuff from maplins a while back . Quote Share this post Link to post Share on other sites
robdriver 10 Posted April 21, 2013 fla said: leds wont work unless you have 3 per dial of the SMDs. If not, just get bulb replacements from Maplins. Maplins sell a strip of 12 volt led on a self adhesive strip I installed a strip of these across the top of the binnacle in place of the bulbs and if you leave the green strip in place it looks exactly like standard. I then took the green strip out and I was pleasantly suprised at the brighter dash illumination that I now prefer last month the clock bulb went and I ordered a bulb from VW that was not the right on I installed the same Maplins LED strip behind the clock and it works fine though a bit brighter now than the other display Ill convert that one soon to get the balance right The led bulbs dont give off heat like the std bulbs Quote Share this post Link to post Share on other sites
