ausgolfer 0 Posted November 27, 2012 Hi Guys, Wondering if there is any specific areas that seem to leak water into the passenger footwell.....I just had the windscreen replaced and thought that this would solve all y water leak issues...apparently not. There was a good rain here last night and the passenger footwell is very damp now. I think I may have to strip out the dash to find the source. Any tips or suggestions? Cheers. Quote Share this post Link to post Share on other sites
dragon green 5 Posted November 27, 2012 Sounds like the heater foliage seal, Have a read of this http://wiki.the-corrado.net/changing_heater_scuttle_foliage_cover_seal.html Quote Share this post Link to post Share on other sites
VR6 0 Posted November 27, 2012 Failing that it's probably the membrane behind the door card or a blocked sunroof drain. In that order I would suggest. Quote Share this post Link to post Share on other sites
carpoid 0 Posted November 27, 2012 The membranes are the usual thing Carl... Mine used to leak because they had rotted away. Hope the Corrado is going well! Quote Share this post Link to post Share on other sites
ausgolfer 0 Posted November 27, 2012 thanks guys I'll check them all out ;) Quote Share this post Link to post Share on other sites
ausgolfer 0 Posted December 3, 2012 On a related topic, does anyone know if those Jetex pollen filters are still available? Cheers. Quote Share this post Link to post Share on other sites
n3p 3 Posted December 3, 2012 Don't think it is. Had the same leak as you by the way, it was the foliage cover Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted December 3, 2012 Have you tried the door seals mine was leaking very badly , i set up a hose pipe spraying at the car then got in a waited to see where it was coming from and the seals was the problem Quote Share this post Link to post Share on other sites
ausgolfer 0 Posted December 3, 2012 Honestly I haven't had a lot of time to check lately, the joys of working at a toyota production plant I do have a big suspicion it is the foliage cover though, as I saw a few drips coming down off the passenger tray under the glove compartment. Quote Share this post Link to post Share on other sites
