B5VWC
Schimmel Big Valve Head Forged Wossner VR6 Engine Block ARP Peloquin Cromoly Helix VT
I am selling my high performance Engine & Gearbox + Uprated Parts perfect for Turbo or Supercharger setups.
All parts have been replaced with high quality or genuine VAG parts I built this to cope with 400hp+ and can prove this with the results I have achieved consistently breaking 400bhp/18pi at Stealth Racing...
SCHIMMEL BIG VALVE CYLINDER HEAD £500.00
OBD2 Cylinder Head (has oil opening for timing chain lubrication)
JB Weld filled, Resurfaced, Hot Tanked, and Assembled
New Phosphorous Bronze Guides & Seals
1mm Oversize Ferea Inconel Valves
Multi Angle Valve Cuts
Shortened Valve Stems
Titanium Spring Caps & Retainers
Heavy Duty 7500rpm Springs
Port Matched Intake: Exhaust & Inlet
ARP Uprated Exhaust Studs
Includes SP 263 Camshafts & INA Lifters
New Prices & Details: Price up this complete spec and it’s going to easily come to over £1000 and more
http://www.spturbo.com/onlinestore/index.php/services/vr6-12v-cylinder-head.html
http://www.spturbo.com/onlinestore/index.php/12v-vr6-camshaft-set-263-street.html
http://www.spturbo.com/onlinestore/index.php/raceware-vr6-24v-2-8l-headstuds-579.html
FORGED 2.9 LITRE VR6 LOW COMPRESSION SHORT BLOCK £1200.00
ABV Block cleaned & repainted using POR 15 products
Original 2861cc 82.0mm Block rebored to 2891cc 82.5mm (True 2.9 Litre) by Stealth Racing
Wossner Low Compression Forged Pistons
Pistons give a compression ratio of 8.0:1 which goes up to 8.5:1 with a steel gasket
Wossner H-Beam Connecting Rods
ARP Uprated Rod Bolts
New VAG Main & Big End Bearings + Caps installed
*Will also include 5L Fuchs Titan Race Pro S 5w50 Oil
New Prices & Details: Price up just the performance & vag parts alone – this is a bargain!!!
http://forged-pistons.co.uk/webshop/wossner-automotive-forged-pistons/volkswagen-forged-pistons/corrado-golf-sharan-vr6-turbo-low-compression-wossner-forged-pistons-9093/
http://www.spturbo.com/onlinestore/index.php/volkswagen/mk3-94-98/vr6/engine/pistons-rods/vr6-h-beam-connecting-rods-5-16-bolt.html
Engine has just over 4000 miles on it. Run in for 2000 miles below 3000rpm. Oil & Filter changed at 500 miles and then 2000 miles. Ran on Fuchs Titan Race Pro S 5w50 Oil and G12++ Coolant only.
02A GEARBOX REBUILT WITH 3.68FD & PELOQUIN LSD £500.00
Original 02A Gearbox Rebuilt by Stealth Racing
3.68 Final Drive installed (snappy acceleration sits in torque rev range)
Peloquin Limited Slip Differential with ARP fittings
New Prices & Details: Bargain price considering the LSD will cost more than this alone
http://www.peloquins.com/products_02A.html
UPRATED ENGINE & GEARBOX PARTS
Cromoly Lightweight 9lb Flywheel £80.00
Helix Sports Clutch £150.00
http://www.helix-autosport.com/performance-clutches/volkswagen/
Schimmel Ignition Leads (8mm) £40.00 >>> SOLD
http://www.spturbo.com/onlinestore/index.php/volkswagen/corrado/vr6-92-95/ignition-fuel/vr6-wire-set-short-runner.html
Samco Black Coolant Hoses £120.00 >>> SOLD
Vibratechnics Front Engine Mount Road - VAG950M £70.00
Vibratechnics Rear Engine Mount Road - VAG885M £40.00
Vibratechnics Gearbox Mount Road - VAG875M £40.00
...OR TAKE ALL 3 FOR £130.00
http://www.vibra-technics.co.uk/vw/golf_jetta_vento_mk_iii
ARP Head Stud Kit with ARP Lubricant £100
These has been advertised on other forums also
FORUM BUILD GALLERY
http://the-corrado.net/showthread.php?6946-Black-VR6-Rotrex-Mapping-Update-on-Pg-20/page23
RUNNING SETUP WITH NEW ENGINE RUNNING IN:
ROLLING ROAD AT STEALTH WITH REBUILT ENGINE @ 28 DEGREES IN WORKSHOP:
RECENT VIDEOS OF CAR AT IDLE & ON THE ROAD:
Edited by B5VWC
Expressing interest in the cylinder head!
Does it come with any proof of work such as receipts? Why are you selling it? Is the head good to go.. i.e. can it be fitted straight away with no other work?
When can you get this removed, will you post and how you want payment?
PM me.
Edited by P3rks
Expressing interest in the cylinder head! I'll have it.
PM me.
All work was done by Schimmel I have detailed Invoice with all the work completed on the head and Receipt for the SP 263 Cams.
Its Cash on Collection only Im in Coventry.
I can remove anytime - I will pm you my contact number.
Got the Pm, I'll drop you a call over the weekend.
Rich
Very good price with you including the cams, similar to my own build but I don't have the oversize valves.
Do you know what the compression ratio is on the block? Ok its the link doh!
Can the obd2 head be put into a obd1 car?
Edited by captainredeye
The whole engine was running in my Corrado, OBD2 Head + OBD1 2.9 ABV Bottom End, the OBD2 head just has oil opening to lubricate the chains thats all the difference really.
My Build Thread is here: http://the-corrado.net/showthread.php?6946-Black-VR6-Rotrex-Mapping-Update-on-Pg-20/page23
Price is good its even better if the whole block is taken as you get the extras and ready to drop in engine will save someone a fortune especially those who have don turbo or supercharged but not uprated their engine: the overall cost saving is huge.
Pistons give a compression ratio of 8.0:1 which goes up to 8.5:1 with a steel gasket.
Edited by B5VWC
Why are you selling?
Where is it, and if not at Stealth, can you get it there?
What's your price for the full setup?
Just moving on mate not using much as you can see the mileage is very low but then its difficult to sell/value a performance car so shifting the performance parts then hopefully put back to standard
£2000 for the whole setup at the moment I feel that is good value for what you get
I am 20 minutes from stealth and, this is how it looks to today ready to lift out and take away
Just have the following performance parts leftover now see page 1 for more details...
Would you courier the gerabox?
Sorry mate would have been collection only
I'll take the gearbox and collect tomorrow as per pm.
Cheers, J
Thanks J See you tomorrow
Cheers, J
If the sale of the gearbox falls through I'll take it and collect at the weekend?
Cheers, J
Gearbox sold tonight thanks JSC999
2nd dibs on the head please.
Sorry mate Head sold last week ~ Just have Vibratechnics Mounts left now
