g-master 0 Posted April 27, 2004 The other day after a long journey in hot weather, for a moment i could'nt get 1st or 2nd gear got 3rd and pulled away :? Then it was fine again but now everytime i press the clutch pedal it make's a squeky noise coming from the engine bay, could this be signs of the cable about to give up the ghost :?: Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted April 27, 2004 arnt g60's hydraulic clutches? Quote Share this post Link to post Share on other sites
stevemac 0 Posted April 27, 2004 dazzyvr6 said: arnt g60's hydraulic clutches? Yup - certainly are Fully hydraulic clutch - not a cable in sight :wink: Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted April 27, 2004 Yep they are! I've heard a lot of corrados make a creak when you press the pedal down, it's coming from inside the bell housing. Probably the pressure plate fingers. Mine does it and I've got a new clutch in there, so I wouldn't worry about that. If you mean a squeal as you pull away, that'll be your release bearing. Quote Share this post Link to post Share on other sites
g-master 0 Posted April 27, 2004 :oops: yeah your right, i was thinking it might be something to do with the gear selector cables :? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 27, 2004 Fluid change might be a good idea, clutch system but Gbox also if its never been done.... maybe slave cyl is starting to go Quote Share this post Link to post Share on other sites
Dilated 0 Posted April 27, 2004 While we're talking clutches, I have a couple of little queries... Sometimes, every once in a while when i get in the car on a morning the clutch pedal has dropped a little. It still changes gear but after a couple of days it sometimes becomes a little notchy. I solve this by pulling the pedal up with my toe, but this leaves the pedal really high up. I like it lower down as it usually is! The fluid is at the right level and not leaking anywhere. It's not so much of a problem, more of an annoyance. Could this be a case of fluid needing to be replaced? Quote Share this post Link to post Share on other sites
Henny 0 Posted April 27, 2004 most likely cause is that one of the former owners used to rest their foot on the clutch pedal and it's worn a slight notch in the master cylinder... depends on how annoying it is to you as to if you can be bothered to change the cylinder or not... :? Quote Share this post Link to post Share on other sites
andycowuk 0 Posted April 27, 2004 Henny said: most likely cause is that one of the former owners used to rest their foot on the clutch pedal and it's worn a slight notch in the master cylinder... depends on how annoying it is to you as to if you can be bothered to change the cylinder or not... :? I just priced slave and master cylinders......Master was around £120, Slave around £35..... I got the slave one to try......got it today......and they are now made of plastic!! how long have they been made of that? Quote Share this post Link to post Share on other sites
Henny 0 Posted April 27, 2004 dunno, my new slave is metal... 8) Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 28, 2004 I think the seals inside the metal casing are now plastic rather than rubber that perishes. My new VW one was metal last year. Quote Share this post Link to post Share on other sites
