chris CORRADO
I think ive used the wrong OIL opppps
It'd be a nice leisurely 30 minutes, with time to make a cup of tea while the oil was draining out of the car. That's how much labour a garage would probably charge you anyway :roll:
Supercharged wrote,
300k!! - I would change it a bit more reguarlythan that
sorry mate, meant 3k :oops:
Most garages these days do an engine flush when they change the oil.. Which is a bit pointless if you're changing it so often..
[quote name="Scott"30 mins!!!! :o
It shouldnt even take you half of that mate!!.... :D[/quote]
Not if you've got a Mocal oil cooler on your G60!
K
Yeah, I do mine every 3k... I used to do every 5k on my Golf but the oil gets hotter due to the nature of the supercharged engine altho I now have the Mocal in place and its chopped 20c of the higher oil temps!
I think Kev is refering to my mocal sandwich plate which sits underneath the OE heat exchanger and makes it imposible to fit a G60 filter on the car without hack-sawing the hex off the bottom first! - still only takes 30 mins mind!!
ya I was wondering about my oil as well...
Mobil 1 super synthetic 15w-50
I live in the north east US, and summer is coming up....
That should be ok right?
That is an excellent option!
15W-50 is best oil type for our countries!
The owners manual advises it to tropical climates.
I am using Shell Helix Plus (semi-syntetic) 15W-50.
But i think that you can use fully syntetic motor oil too without problems!
