twin45
a few breakers
  matt59876 said:
Do you have a late passenger side wing available?
Yer £50 collected can post for extra
  keany221 said:
still got a pedal box, m/c and reservoir? preferably with lines too if ya have. price for postage?
£100 plus post for the lot cheers
Only got 90mm with cracks in no mint ones
got a piller trims £15 each plus post
so £35 posted the pair cheers
  Langsam said:
Have you got a grey parcel shelf in good nick with no cutouts for speakers?
30 posted cheers
Yer we have several instock do you have a part number so can defo get right one cheers
Do you have the cable that connects to the abs pump? Just need the multi pin connector and as much of the cable as possible. For a 95 vr6.
Hi, Do you have the cable that connects to the abs pump on a 95 VR6? Just need the multi pin connector and as much of the cable as possible.
now have a late k reg 2ltr 16v in lc5u
full grey heated leather seats
and a satin black early kr 16v
[ATTACH=CONFIG]77007[/ATTACH][ATTACH=CONFIG]77008[/ATTACH]
Hi Steve, my fuel/temp gauge has packed in. I need the dial unit which just slides onto the main instrument panel. This is the late spec one where the digital display (clock etc) is fixed to the circuit board, not removed with the dial Have you got anything?
Thanks
Andy
Alright mate, do you have a good condition 90mm splitter, and are you willing to post? If so, how much posted? Thanks, Sean.
