delfinis38 1 Posted May 18, 2016 Good effort! Nice to see things being done properly! :thumbleft: cheers... hopefully I will have a few hours tomorrow to finish it. Quote Share this post Link to post Share on other sites
robrado974 1 Posted May 18, 2016 They look really nice . I would like s set of these . Quote Share this post Link to post Share on other sites
diarmaid16 1 Posted May 18, 2016 Nice work. Have a set of these to fit down the line Sent from my GT-I8200N using Tapatalk Quote Share this post Link to post Share on other sites
delfinis38 1 Posted May 20, 2016 Nice work. Have a set of these to fit down the line Sent from my GT-I8200N using Tapatalk What a PITA getting the new sender in... I have airco pipes in the way so makes it a bit more complex and the new sender has a tapered thread. After a few hours and a few chopped spanners, and a rather grazed arm where I've been putting it through the headlight and down by the alternator it's all connected up and working... Yippeeee. Quote Share this post Link to post Share on other sites
GlosterOx 0 Posted May 20, 2016 What a PITA getting the new sender in... I have airco pipes in the way so makes it a bit more complex and the new sender has a tapered thread. After a few hours and a few chopped spanners, and a rather grazed arm where I've been putting it through the headlight and down by the alternator it's all connected up and working... Yippeeee. Well done, good aren't they? Ian. Quote Share this post Link to post Share on other sites
delfinis38 1 Posted May 20, 2016 Well done, good aren't they? Ian. Yes... Worth the hassle 😄 Quote Share this post Link to post Share on other sites
diarmaid16 1 Posted May 20, 2016 Good stuff! How did you know what plug and loom to get? Sent from my GT-I8200N using Tapatalk Quote Share this post Link to post Share on other sites
delfinis38 1 Posted May 20, 2016 (edited) Good stuff! How did you know what plug and loom to get? Sent from my GT-I8200N using Tapatalk If you read all the stuff in the search on guages your find the part numbers.. You need 1J0 972 704 which is the black plug @ £4.28 000 979 133 E which is the wire set... I ordered 4 wires but you can get away with 2 as they have plugs both ends and you can chop them in half. They are 3 quid each.. To be honest you could just buy the wire and terminals for the plug off eBay and make them up yourself. Would be cheaper. Or I've been told it's the same plug as a mk3 golf sunroof motor... Hope that helps Edited May 20, 2016 by delfinis38 Quote Share this post Link to post Share on other sites
diarmaid16 1 Posted May 20, 2016 That's great, thanks. Sent from my GT-I8200N using Tapatalk Quote Share this post Link to post Share on other sites
delfinis38 1 Posted May 21, 2016 any comments on what readings I should be getting out of my pressure gauge... this is on tick over. Quote Share this post Link to post Share on other sites
diarmaid16 1 Posted May 21, 2016 At idle about 2 bar when hot and 4 bar cold. Sent from my GT-I8200N using Tapatalk Quote Share this post Link to post Share on other sites
GlosterOx 0 Posted May 21, 2016 I get 6 bar when stone cold that again reduces to 2 bar when hot and idling - I have a rebuilt alternator also so I get around or just over 14 volts depending on load. Ian. Quote Share this post Link to post Share on other sites
16VG60 1 Posted May 21, 2016 I get 6 bar when stone cold that again reduces to 2 bar when hot and idling - I have a rebuilt alternator also so I get around or just over 14 volts depending on load. Ian. Your gauge reading for oil pressure is spot on and the colts are good too, nothing to worry about there. Quote Share this post Link to post Share on other sites
delfinis38 1 Posted May 21, 2016 Your gauge reading for oil pressure is spot on and the colts are good too, nothing to worry about there. is that a reply to me or glosterox Quote Share this post Link to post Share on other sites
GlosterOx 0 Posted May 21, 2016 Your gauge reading for oil pressure is spot on and the colts are good too, nothing to worry about there. Thanks John that is very encouraging to read, as the engine has over 227K on the clock! Ian. Quote Share this post Link to post Share on other sites
16VG60 1 Posted May 21, 2016 Just illustrates what these engines can do when in the loving care of an enthusiast Quote Share this post Link to post Share on other sites
delfinis38 1 Posted May 22, 2016 (edited) new battery fitted this morning, I also put waxoyl on the battery tray for a bit of protection. really need a proper battery clamp. when the guy fitted the airco years ago he lost it and replaced with some washers, last time I fitted a battery I bent a piece of metal up to hold the battery... its not ideal but works. fitted one of Matt's after market headlight switch's not a fan of the red illumination that is always on. might put my old switch back, only changed it as its got a scratch on it. bit of a polish if I get time later. Edited May 22, 2016 by delfinis38 Quote Share this post Link to post Share on other sites
delfinis38 1 Posted May 25, 2016 anyone taken an old battery to the scrappy recently..... any idea what scrap car batteries are worth these days.... I'm guessing 6kg lead Quote Share this post Link to post Share on other sites
Harrier 1 Posted May 25, 2016 anyone taken an old battery to the scrappy recently..... any idea what scrap car batteries are worth these days.... I'm guessing 6kg lead My local breakers gives £3 a battery. Quote Share this post Link to post Share on other sites
delfinis38 1 Posted May 26, 2016 Thanks harrier... Not worth me going out of my way to do at the moment then.... I had something in my mind of about7.50. But that may of been a leisure battery we had on our boat. Quote Share this post Link to post Share on other sites
delfinis38 1 Posted June 3, 2016 (edited) got a few projects on the go at the moment... seats are out for a good hoover. and been cleaning and waxing the wheel arches.... bought a new toy which keeps getting in the way with car progress... A table tennis table :) when the weather warms up I guess it will go in the garden. and normal garage activity will resume. will try and do a brake fluid change at the weekend. Edited June 3, 2016 by delfinis38 Quote Share this post Link to post Share on other sites
ChrisL 20 Posted June 3, 2016 I didn't think table tennis tables needed brake fluid? Quote Share this post Link to post Share on other sites
delfinis38 1 Posted June 3, 2016 Ha ha... The corrado does though. Quote Share this post Link to post Share on other sites
delfinis38 1 Posted July 6, 2016 not done much recently.... been painting the house and on holiday. (hence the ladder) fitted new battery last month, bought yet another set of mats to add to the collection, upgraded all the old nokia speakers... and fitted new side repeaters as when I removed the old ones the clips were brittle. had a bit of a polish yesterday... Quote Share this post Link to post Share on other sites
delfinis38 1 Posted August 25, 2016 Arch lining out this morning for a clean and change of fixings... Side repeater replaced and new brake pads fitted.... ooo clean car cover washed in the bath yesterday... I know you guys like pictures :)oil and filter change last week. Quote Share this post Link to post Share on other sites
