Jim Bowen 1 Posted November 19, 2013 Anyone used one of them radweld products, my rad seems to have a very slight leak (a bit gutting as it was a brand new VW one and just run out of warranty (typical) Tempted to shove some radweld in as getting a bit fed up with coolant leaks now, Is it likely to be a bad idea or not? I know some people would never use these sort of things and i've been one of them in the past. Quote Share this post Link to post Share on other sites
southerner88 10 Posted November 19, 2013 I have never used it but.... mate with a Pug GTi6 used it, ended up clogging up the system as it turned the coolant to what looked like Jelly. Engine overheated and caused all sorts of problems for him...still hasnt managed to fully clean it out...personally I would stay well away... Quote Share this post Link to post Share on other sites
Harrier 1 Posted November 19, 2013 There is a product called 'k -seal ' which is quite good & doesn't clog everything up. Usually available from motor factors Quote Share this post Link to post Share on other sites
EJ Taylor 22 Posted November 19, 2013 Did someone say...... Rad Seal? [ATTACH=CONFIG]76458[/ATTACH] (K-seal is meant to be the best) Quote Share this post Link to post Share on other sites
EJ Taylor 22 Posted November 19, 2013 my talent is wasted on this forum! Quote Share this post Link to post Share on other sites
Jim 2 Posted November 19, 2013 You sure it's the radiator leaking.. like 100% sure? Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted November 19, 2013 yeah am sure its leaking, must be very small as the level hardly goes down, had the front grill and lights out yesterday and noticed pink crust down the edge of rad, can always smell coolant when walking about the front end. I liked the rad seal btw EJ, is he a personal friend? Quote Share this post Link to post Share on other sites
Dox 31 Posted November 19, 2013 Try reseating the hoses if they're in the same area as the leak, check for pin holes in the hoses too. I wouldn't use any gunk on a coolant system unless the car is scrapyard fodder to be and the stuff would extend the cars life for a month or two Quote Share this post Link to post Share on other sites
EJ Taylor 22 Posted November 19, 2013 yeah am sure its leaking, must be very small as the level hardly goes down, had the front grill and lights out yesterday and noticed pink crust down the edge of rad, can always smell coolant when walking about the front end. I liked the rad seal btw EJ, is he a personal friend? Well im glad somone on here did!!!! i dont see him any more he used to be a god mate but i always suspected he was upto something, something fishy about him. Quote Share this post Link to post Share on other sites
Micky fletch 10 Posted November 19, 2013 your a star EJ with punch lines like that.Move over Bruce forsyth. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted November 20, 2013 There is a product called 'k -seal ' which is quite good & doesn't clog everything up. Usually available from motor factors Yeah the RAC carry that in their vans. I've used it in my Rover 25 (K series and K - seal, a coincidence? lol) as it had a very slight weep from the head gasket (non pressure side). It went from using a litre of water a week to a litre every 6 months, so yeah, it works :) Quickest way to tell if this kind of chemical has clogged the coolant system is try the heater. If it's cold, it's blocked. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted November 20, 2013 Do i recall someone mentioning that you should never use a rad seal type product on a VR as there are very small water channels that aid the block cooling & can easily become blocked.....or something like that EJ - that pic cracked me up ;) Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted November 20, 2013 There's a 2 part putty you can buy, mix it together and then apply it to the leaking area on the outside..... nothing goes into the cooling system. Quote Share this post Link to post Share on other sites
