robrado974
Which multi meter ?
I need to buy a multi meter . Looking online the prices vary a lot . What have you got ? What's the Best value for me dough .
Thanks
Rob
I've got a Fluke but they are at the higher end of the market. Tbh Rob, anything cheap that'll measure voltage, resistance, current and continuity will serve you well, regardless of price. I had an old ten pound jobbie from B&Q before and it did exactly what I needed, it just wasn't waterproof unfortunately.:rolleyes:
Thanks Sean , usually when something is priced at £5.99 and another at £89.99 you think somewhere in between would be good , but for under a tenner it must be crap . Just need to read up on how to use one now lol .
Rob
I'm not a fan of the buzzer option personally. I use a meter daily and have learnt to never trust the buzzer function. Always had fluke go digital display and fused leads not sure if there is another option
I suggest getting a clamp meter, does everything what a basic multimeter but measures Amps as well,
I got mine 2nd hand off ebay, here's one from `maplin
http://www.maplin.co.uk/uni-trend-203-dc-ac-current-clamp-multimeter-629713
Also, to add,
I don't like autoranging multimeters, they take too long to stabilise their readings, we normally know the voltage range we need to test on cars, 0-20V range
Edited by J.C
I would suggest a multimeter with auto-off function.. cant remember all the times I needed my multimeter and its dead from being left on for weeks.
+1 for sure!!!
4 things I find useful in a meter:-
1) Backlit LCD for those dark areas
2) Current measurement of at least 20A for parasitic load tests.
3) A range of lead ends, including crocodile clips.
4) Buzzer for continuity testing
The price difference is sometimes caused by option 2 as it needs much heavier duty circuitry.
Looks good to me mate. Pretty standard design for the more robust and class leading meters of a few years ago so cant go wrong with that!
Edited by seanl82
Looks ok to me too , thanks very much for everybody's input .
Rob
Temp function is what I'm needing, my meters are an ancient micronta and a couple of aldi cheapies. I'm going to get that one above.
