J.C
heater controls, backlight kit,
I'm still interested in one with red outer rings and blue/red centre ring if you can. Pm me payment details.
Thanks
The following people have PM'd me their order and were one of the first 20 who expressed an interest,
You are gauranteed a panel,
GlosterOx- Thanks for your order,
seanl82- Thanks for your order,
Goldie- Thanks for your order,
bigchagg- Please reconfirm by pm, with your details,
Roger Chatfield- can you pm me with your details,
jscVR6- can you pm me with your details,
MikeVR6- Thanks for your order,
Jon_vr6- Thanks for your order,
Ruggy- Thanks for your order,
kevinbowe2000- Please pm me with your details,
fla (blue outer dials)- Thanks for your order,
matt59876 (red outer dials)- Thanks for your order,
easypops- Thanks for your order,
Dude VR6- Thanks for your order,
The following is a list of people who (in order) have expressed interest in the thread but have not pm'd me,
Please note that you need to PM me to order.
Talltorrac
JD Westy
n3p
st4stokie
Micky fletch
Wesleyvr6
jamie_300
science
Roger Blassberg x2
jontykint
Mike16v
Hofmiester
geoffersmaher
imyhamid
swiftkid
Big_Al
wapadrand
mithoule
I am going to wait until the end of the weekend then I will pick the 4 highest people on the list which have pm'd me
cheers
Steve
p.s looks like I'd better get started on the 2nd batch!!!
Cool, let me know when you want the cash and I'll do a bank transfer for you.
Instructions
[ATTACH=CONFIG]78574[/ATTACH]
remove ashtray,
[ATTACH=CONFIG]78575[/ATTACH]
[ATTACH=CONFIG]78576[/ATTACH]
Remove ashtray housing, phillips screwdriver,
[ATTACH=CONFIG]78577[/ATTACH]
[ATTACH=CONFIG]78578[/ATTACH]
[ATTACH=CONFIG]78579[/ATTACH]
[ATTACH=CONFIG]78580[/ATTACH]
Carefully prise panel away with a flat screwdriver, Be carefull as the plastic is old and potentially brittle,
[ATTACH=CONFIG]78581[/ATTACH]
[ATTACH=CONFIG]78582[/ATTACH]
Once again be carefull in prising away the original light rings,
[ATTACH=CONFIG]78583[/ATTACH]
Position new panel with the lead exiting at the cigarrette lighter area,
[ATTACH=CONFIG]78584[/ATTACH]
Optional, refit the green light ring, this is a bit tricky to fit as you need to bend the faceplate to get the tabs in place, if you couldn't refit the green ring, the panel can be fixed in place by bluetac etc,
[ATTACH=CONFIG]78585[/ATTACH]
Loosen the cigarrette lighter by sliding it to the left and pulling forward,
[ATTACH=CONFIG]78586[/ATTACH]
Feed panel lead through the opening above the cigarrette lighter,
[ATTACH=CONFIG]78587[/ATTACH]
refit the panel,
[ATTACH=CONFIG]78588[/ATTACH]
refit the cigarrette lighter,
[ATTACH=CONFIG]78589[/ATTACH]
lay the blue wire (to ashtray light) into the connector as shown,
[ATTACH=CONFIG]78591[/ATTACH]
clamp the blue cable between the connectors halves,
[ATTACH=CONFIG]78592[/ATTACH]
feed the invertors red wire into the right channel and make sure it goes all the way in to the end (about 15mm), crimp the cables with a pair of pliers,
[ATTACH=CONFIG]78593[/ATTACH]
secure the locking tab,
[ATTACH=CONFIG]78594[/ATTACH]
[ATTACH=CONFIG]78595[/ATTACH]
[ATTACH=CONFIG]78596[/ATTACH]
repeat for the other wires (brown to the ashtray light and the invertors black wire),
[ATTACH=CONFIG]78597[/ATTACH]
optional, I covered my invertor with some pipe lagging foam I had lying around in the garage, it's not neccasary but stops any potential rattling.
[ATTACH=CONFIG]78598[/ATTACH]
connect panel to the invertor and position invertor into area behind the ashtray,
Refit the ashtray housing.
THE PANEL OPERATES AT A HIGH AC VOLTAGE (approx 200V) SO THEREFORE IS DANGEROUS, I HAVE SEALED THE EDGES BUT THE UNIT SHOULD ONLY BE POWERED UP ONCE ALL THE PANEL HAVE BEEN PUT BACK,
I HAVE TRIED MY BEST TO SUPPLY A GOOD PRODUCT AND DETAILED INSTRUCTIONS BUT IF YOU FEEL IT IS NOT WITHIN YOUR CAPABILITIES OR YOU ARE UNHAPPY IN ANY WAY, YOU CAN RETURN THE PRODUCT FOR A FULL REFUND
ANY QUESTIONS PLEASE ASK,
Steve
Edited by J.C
Thanks to all who have paid,
The backlight kits have been sent,
Hopefully you will recieve them before the weekend, if they havent arrived by next Wednesday, let me know,
Cheers
Steve
Hi
You don't have to isconect the battery because, The unit turns on with the light switch and that will of course be off, also by the time you connect the panel to the invertor (little 2 pin plugs) the panel is safe and sound already installed in the dash,
Just to reiterate, I have been handling these panels and have not had any problems but I just want to sure.
However, no matter how carefull you are, silly mistakes can be made, like the time I couldn't be arsed to get my wire strippers and proceded to strip the wires with my teeth only to find it was still connected to a powered invertor, that was a bit of a shock:bonk:
Haha :cuckoo:
Hi bud, looks like I may be a little too late but I would like one of these with purple lit outer rings if you produce any more,
Thanks,
Alex
Thanks,
Alex
Mine arrived today, much appreciated Steve. Well packed and looks pretty nicely made too! Will be a while before i fit them though, but certainly look forward to seeing the results. I'll take some trial pics hopefully over the weekend so others can see.
Many thanks for your efforts on this project.
Talltorrac
JD Westy
n3p
st4stokie
Micky fletch
Wesleyvr6
jamie_300
science
Roger Blassberg x2
jontykint
Mike16v
Hofmiester
geoffersmaher
imyhamid
swiftkid
Big_Al
wapadrand
mithoule
cheers
Steve
Still awaiting your bank details Steve so I can send you seme money?
Ian.
How did I miss out on this? Could I please get my name down for a kit? Would quite like OE colours with red / blue for the temperature dial but happy with just OE colours for the whole panel.
Sorry Ian, I'll Pm you them
Ian.
