Roger Chatfield
What's wrong with my sunroof
Evening all,
I've known since I got my Storm that there was a problem with the sunroof so today I built up enough courage to give it a go.
Now it tilts fine however when I try to open it problems start.
If press the open button the roof panel moves back about 5mm and then stops, if I press the button again it does the same, moves another 5mm and stops, I can keep pushing the button and get the roof open but in 5mm step ( I've only opened it a third), the same happens when I close it but in reverse, it will close but in 5mm steps.
Anyone have any clue what's wrong?
Rog.
New motor needed. Mine was doing the exact same thing! Get a motor off a breaker, and I reckon you'll be back in business :)
Sounds similar to the problem mine had too,I stripped mine all out only to find it was just the motor at fault. I replaced it with a mk3 golf motor which looks a little different but works fine & much easier to get hold of.
yeah no need to take head lining out, just take off light cover panel and its a forward enough swap, mine turned out not to be the motor and after much frustration with it, I thought, who needs a sunroof?
As has been said Rog, dead easy - 10-15 minute job tops, and the only tool you need to accomplish it is the screwdriver in the factory toolkit :)
Had exactly the same problem - tried 3 motors and two switch panels before I gave up and ended up swapping the cassette for a MKIII Golf one. Been fine ever since.
Yep. Changing the motor is band aiding the problem. The motor is struggling because the plastic feet of the 'water plate guides' (VW terminology) are binding in the cassette channels.
A more permanent cure is strip it right down, replace the water plate guides and reassemble with silicon sliding mechanism grease......or stick a MK3 one in.
All Passat and & Corrado roofs go the same way. The Golf doesn't do it as much for some reason.
