Jamie
Silicone hose clips
Just a quick one - is there any advantage to using the specific Samco hose clips or will the Screwfix stainless Jubilees do the job just as well?
Jubilee type doesn't produce even pressure all the way round and can create a pinch point, slicing into the hose. Use jubilees with care or buy silicone hose clamps the original Corrado twin eared type can also be used.
Am swapping all my jubilee clips back to spring type clamps. They are much better.
I keep meaning to post up all the sizes you need.
vw knows best heheh , i hate seeing the jubilee clips on a vw engine
Damn. I've got boxes of Jubilee clips in loads of different sizes :lol:
If you could whack a list up Jim it would really be most appreciated mate
Edited by Jamie
Roose motorsport sell a clamp kit
Yeah thirty five notes though Matt and cos I'm brassic I was trying to do it on the cheap... ;)
Usually id agree there mate as im a fellow tight ******* haha , but when you think that 35 quid could save ypu a gose popping off id say its not a bad investment
A goose popping off? You crack me up bud!
the clips I got from roose seem great, easy to work with and no leaks 1st time.
Last thing I want is to pop a goose so yeah I suppose £35 is money well spent in prevention
ASH is a good call James - I just got a BMC coupler for less than £3 off them. I'll give them a shout
I got mine from a place called hcl clamping, just need to get my list together of what i bought, as i bought loads wrong in my first order.
If your using silicone hoses,use this first
[ATTACH]80198[/ATTACH]
It never goes off,but helps seal the hose,I've had no leaks since using it
Right sorry to drag this up again but I've just been looking at the JCS hose clamps that Roose supply, can anyone tell me the difference between these and Jubilee clips? They look identical to the ones I have just a different manufacturer...
I thought the roose ones was the squeezy ones you have to have a proper tool for !! Abit like how the corrado has its owners haha
This is the pic they show Matt
Edited by Jamie
They all seem to be made by a place called JCS. I bought loads and looked at loads and ended up coming to the conclusion not that many people make jubilee clips. They just buy them in.
I did have problems with hoses popping off or leaking and the clips damage the hoses. I'm only going to use the spring clamps on coolant hoses from now on.
