seanl82 23 Posted January 23, 2016 Drop the passenger undertray and lift up the carpet. Stick your head in there and get someone to use a hose around it. Could be sunroof drain leaking down the A pillar trim, a poorly fitted windscreen, door seal or wing mirror seal, as well as the scuttle cover as mentioned. Worth checking it out whilst you're waiting for a new one to arrive. Quote Share this post Link to post Share on other sites
EssexPaul 10 Posted January 23, 2016 The carpet is wet from the top right where the seal would be. I did have the windscreen replaced in August so I shall get Autoglass out to check it Quote Share this post Link to post Share on other sites
Cressa 46 Posted January 23, 2016 I changed my scuttle seal last week. Got it from heritage and followed the wiki on here. Relatively easy. Looking at your picture, have you removed the end part of the windscreen lower scuttle trim? As this helps deflect water away from the scuttle motor cover area. Whilst doing this its a great time to clear all the old rotted leaf products and the drain hole that goes through the inner wing. Not an expensive job even if it isn't this that's leaking Quote Share this post Link to post Share on other sites
Cressa 46 Posted January 23, 2016 Ignore my missing trim comment. ....I've seen it now. Should have gone to specsavers! Quote Share this post Link to post Share on other sites
EssexPaul 10 Posted January 24, 2016 Cheers Cressa! I think it was removed when I had an issue before. Thank you all for your help so far. I have been trying to get the car ready for sale would you believe since last summer but it has been problem after problem like you wouldn't believe! Quote Share this post Link to post Share on other sites
Cressa 46 Posted January 24, 2016 Its your corrado. Don't get rid, just repair. .... its an easy fix Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted January 25, 2016 EssexPaul said: Cheers Cressa! I think it was removed when I had an issue before. Thank you all for your help so far. I have been trying to get the car ready for sale would you believe since last summer but it has been problem after problem like you wouldn't believe! the scuttle cover that is in your 1st picture could be the issue, rather than the foliage seal I say this as I had an issue with the VR where someone had not fitted the scuttle cover you pictured correctly, such that the side of the cover closest to the wing was bent under the top of the cover. this in turn caused a tiny gulley which was allowing the rain water to run directly into the top of the foliage cage thing. the foliage cage seal was perfectly fine but as the cover side had been crushed when fitted the water wasn't even hitting the seal the scuttle cover side closest to the wing should be a flat vertical which comes down far enough to almost hide the foliage cover Quote Share this post Link to post Share on other sites
VR-Sixy 0 Posted January 25, 2016 seanl82 said: Welcome Paul! Classic Green Storm, top of the pile in my opinion! :smug: :thumbleft: No bias there then Sean!! :) Quote Share this post Link to post Share on other sites
EssexPaul 10 Posted January 27, 2016 Can the scuttle cover that I pictured be purchased? I tried getting a new one from VW themselves but they told me that the part had been obsolete for years :( Quote Share this post Link to post Share on other sites
delfinis38 1 Posted January 27, 2016 EssexPaul said: Can the scuttle cover that I pictured be purchased? I tried getting a new one from VW themselves but they told me that the part had been obsolete for years :( Give VW heritage or classic part a call in the morning... An alternative is an aftermarket full length scuttle panel that goes wing to wing. Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted January 28, 2016 If you're not after a new one I have a spare Quote Share this post Link to post Share on other sites
