Harrier
Removing door triangles ?
Hi all,
Does anyone know how to remove the black triangle exterior trim by the door mirrors ?
Thanks
Daren.
You need to remove the inner triangle Daren. There is a single screw hidden behind there. Once removed, the outer one should slide back and come out.
Ok, thanks Sean.had removed the inner triangle but didn't spot a screw. Will look properly tomorrow !
Actually I think that's wrong! The outer top door seal loops over and looks like it has a push clip to keep it in place. This is just a cover. Peel it off to reveal the screw!
As this but there is a plastic funny shaped washer be sure not to misplace ;)
