Wayne2015
VR6: Stalling coming to junctionp
Hi
Read so much about this problem on here,
Golf forum,
Pistonheads etc etc
But there is no CLEAR definitivr solution :( :( :(
It started to stall once every other day -
Be it warm, cold, oil temp low or 100 degrees.
BUT always when changing down towards a junction.
The battery light comes on and if i rev it enough its ok.
Else that split second the battery light comes on- it stalls :(
Its done it EVERY DAY now for 3-4 days in a trot
Now SIX times in a 60min lunch break :(
Is there somewhere i can start with solidly?
I read about -
1. Clean ISV
2. Check MAF
3. Clean throttle body
4. Reset ECU
5. Check all intake pipes...
Help?!!!! :(
There's a damper box attached to the ISV. This is filled with foam, which can get sucked into the ISV, and due to the heat from the exhaust they are prone to cracking. I'd check this also.
  MZpog said:
Are you pressing the clutch? Only joking but does it stall in neutral too?
ALWAYS neutral, Stuart!
Cant really keep my eyes on the dash and road at same time,
But:
1. ALWAYS when slowing down
2. AND in the MIDDLE of changing down
3. AND always in neutral
The EXACT SCENARIO seems to be:
1. Coming to junction (or slowing down)...
2. Nearly stop, depress clutch, neutral
3. Think the rev just dipping to 400rpm
4. Battery light flickers
5. Battery light
All steps 3-6 in a split second ...
6. STALLED !
Where is this exactly?
Just to clarify again
When key is position 2 on dash:
1. Battery light on
2. Handbrake light on
3. Oil lamp light FLASHING??????????????
1. Battery light on
They should all read that way without the engine running :)
If you can nurse it down at the weekend Wayne, I'll go through everything with you and we can give the car a bit of a healthcheck mate.
Got the lose tape!
And NO, its NOT a selfie-stick LOL
Leaking coolant?
YES!
Well this be the caused?
But if it is shouldnt it just overheat engine at all speeds/rev?
Not just stalled at 400rpm in neutral?
If it's loosing coolant quickly, just use tap water temporarily until it's sorted. You'll only have to replace the lot anyway once it's fixed as there won't be much anti freeze left if your constantly topping up. possible causes are radiator, hoses, or crack pipe from around that area. Keep a close eye on it if I were you until it's fixed. Again mate, if you're comfortable with it until Sunday we can have a good look over and I'll point you in the right direction. Saves a few pennies in garage labour too!
  GlosterOx said:
Better to use Demin water if you have some.
Ian.
Demin?
Can I just ask for that at motor factor?
No special type or grade???
Demineralised and yes you can get from any motor factor - I think Tesco do it in their car section too
Thanks Chuggs!
U can tell I know nothing about cars - even though I owned quite a few already :(
Wow - your car only got 54k :)
Cheers Sean!
Hopefully no more winter -
Will top up with water for now ....
  Wayne2015 said:
Thanks Chuggs!
I don't know an awful lot, but like yourself am on a steep learning curve and enjoying every minute of it! Yes she has been pretty well looked after I am now custodian and am gonna try and do the same! I'm even having my garage extended so I can get her in - not cheap this Corrado owning!!! - but based on my cheesy smile on my Sunday drive - worth it!
Lol
Same here, buddy.
Have only owned a couple of late 80s Jap cars -
Learnt a lot about them!
Mostly engine and electrics are solid :)
Rust is the killer plus water leaks.
But when looking for the Corrado -
I applied the same technique.
But still plenty of learned from owning one and from owners on here :)
Deffo BIG grin on my face too driving it DAILY :)
UNTIL the constant stalling :(
Auto rear spoiler is the most talking, finger pointing and amazed looks in the rear mirror on my car - lol
Edited by Wayne2015
I changed my rad the other week, used demin water bought it from Morrisons was cheap so bought enough for several years.
If it comes to a rad change wayne there is plenty of info on here to guide you, hopefully it will be a hose like Sean said, (good to have someone like him to help you as well very nice of him i say).
Here's my thread i posted when i was tasked with the rad change. As i wasn't so lucky http://the-corrado.net/showthread.php?t=89593&highlight=Ray1965
Cheers Ray :)
Sean - u got a fan club??? ;-)
I deffo will faint tackling such jobs!
Hence I lose money every time I buy a classic :-(
But thanks - good background info so that I will know the garage doing job proper - and know where to source a good radiator from too :)
