rado-steve
1989 Nugget Yellow 16V/20VT Corrado Breaking! Lots & lots of Parts! Sad Times :(
Well It's with a heavy heart that this has gone the way it has but I'm Breaking my Lovely Nugget yellow Corrado!
There's quite a lot of stuff left, but most of the big stuff has gone, so Brakes, suspension, rear beam, gearbox, FMIC, Turbo, Exhaust, Doors, Wings, Lights, ARB's
How it currently sits (Well until I removed the Doors & wings yesterday)
So Whats left......
Bonnet, its a VR one, It will need stripping as its a bit sooty!
Front Subframe
Front X-Member with Poly Bushes
Fuel Tank & tank Straps (These were new from VW a few years ago)
Dash & under dash parts
Black A,B,C Pillar trims & rear parcel shelf supports
Various Switches, Spoiler control module, Electric Window control etc.
Almost brand new Genuine VW Heater matrix & Heater Box etc
ABS Parts such as ECU & ABS unit under the bonnet
Headlining
Sunroof & good sunroof seal
Spoiler Motor
Rear Bootlid
Seatbelts
Various trim parts!
Wiper Motor & mechanism
Steering Rack
G60 Drive shafts
Partially polybushed front arms
K-Jetronic Fuel Pump, this was a Brand New Genuine Bosch unit only fitted a few years ago
Door seals
16V Clocks
Early & Late Steering Coloum & UJ
Pedal Box & Hydro Clutch (Throttle pedal delete)
Plus other bits
I also have a full Haldex 4WD Set-up for sale & a 1.8T ECU & Harness set!
Contact me here, PM or on Zero7971 Six23155 for any parts you may want!
I can get pics of specific parts if needed, The large parts are collection only, I can post most of the smaller parts.
Car is located in Darlington, North East
Cheers
Steve
Ok, So Bits etc:
1.8T Secondary Air Pump, £20
1.8T Bolt Down Hitachi OE Coilpacks Part No. 06B 905 115E, £20
2 x AUQ 1.8T Pistons, £10
1.8T Ko4 BAM OE TIP, £15
1.8T Ko3s AUQ OE TIP & MAF Housing, £20
Mk2 Golf Gearshift Repair Kit, Fixes that wobbly Gearshift Mech, £10
VW Corrado Blower Motor May also Fit Mk2 Golf, £15
VW Corrado Black A,B,C Pillar Trims, A few marks as shown on pics but otherwise very very good, £50
Under Dash Trims: £15, Gear Surround: £5, Rear boot Trim: £5
VW Corrado/Mk2 Golf Subframe & Rear engine Mount, Gearbox Mount. Powder coated but showing some signs of surface corrosion: £30
VW Corrado Poly Bushed & powder Coated Front Subframe & Front Engine Mount:£60
Mk2 Golf/Corrado Part Poly Bushed Front Wishbones, Surface corrosion on one: £20 the pair
Corrado Door Handles, one with Dave16v modded striker (will throw in 3rd handle too): £80
Brand New OE VW black Plastic Wiper Motor Covers: £20 each
VW/Audi 1.8T Genuine OE Post CAT Lambda Sensor, Part No. 258 006 978: £15
Corrado ABS ECU: £50
Corrado ABS Pump: £40
2 x Corrado Heater Slide Panel, Fully Working: £10
Mk2 Golf Heater Slide Panel, All working: £10
Mk2 Golf Big Bumper Bumper Guides: £10
Corrado Black Rear Ashtray: £10
2 x Corrado One Touch Window Control Unit: £10
Corrado Rear Boot Light Units: £10
Corrado Spoiler Control Unit: £20
Corrado Wiper Motor: £10
Corrado Rear Wiper Motor: £10
Corrado Leather Handbrake Handle & Black Plastic Lever cover: £20
Corrado Door Handles: £10
Early Type Corrado ABS Light: £15
Corrado/Mk2 Golf Door Pull Handle Surrounds: £10
Full set of Fully working Corrado Electric Window Door Switches: £20
2 x Corrado Clock Blanks, Both stay on but have one of the clips broken: £10
Corrado Fag Lighter: £10
2 x Corrado Courtesy Light in Black: £15
Corrado Sunroof Switch: £5
Corrado Spoiler Switch: £5
Corrado Fog Light Switch: £10
Corrado Heated Window Switch: £10
Corrado Front Ash Tray: £10
Corrado Inner Door Triangles: £15
Corrado MFA stalks, Early Type: £20
2 x Corrado/Mk2 Golf Fuseboard: £10
Corrado Drivers Side Door Window Switch: £10
Corrado Passenger Side Door Window Switch: £5
Corrado Sunroof Motor: £15
Corrado Main Light Switch, Seems a bit rattly but worked ok: £10
Corrado Unleaded Fuel Blank: £5
Corrado Electric Mirror Switch, writing rubbed off slightly: £10
Another Corrado Fag Lighter, Not as nice as last one: £5
Corrado Wiper Motor & Mechanism: £20
Corrado Seatbelt Loops: £10
Corrado Seat Runner Trim: £10
Corrado Door Kick Trims: £20
Corrado Drivers side Wiper Trim: £10
Forge 1.8T (May fit non 1.8T Oil Cap & Water Cap) Billet Alloy Water & oil Cap: £40
VW/Audi 1.8T but may fit other Engines, Billet Aluminium Dipstick: £30
Corrado Audioscape Dash Pod with Autometer Boost & Voltmeter, Matches std Corrado Instruments: £50
Corrado VR6 Steering Coloum & UJ: £30
Corrado Non ABS Servo: £15
Febi Mk2 Golf/Corrado Top Strut bushes, Good condition, no splits or cracks: £10
Mk2 Golf GTI 8v/16v or Corrado 16v OE VW Spark Plugs by NGK BNIB BKUR7ET or 101 000 033: £10
Will the abs pump work for a 94 vr6
Think they are a 6 Outlet, this is a 4. Check yours & get back to me :)
More Parts........
Mk2 Golf/Corrado Front Engine Mount & Rear Engine Mount: £10
Mk2 Golf/Corrado Std Front Wipers: £10
VW/Audi 1.8T Ko3s Turbo Brace Bracket: £10
VW/Audi 1.8T Inlet Manifold brace: £10
Mk2 Golf/Corrado Mk4 Golf Rear Caliper Conversion with Correct Flexi Hoses: £20
Corrado Gear Surround: £5
Corrado Boot Gas Struts: £10
Early Style Corrado Grill with 16v Badge (Badges do £15-£20 on ebay all day) 1 Broken Clip: £10
Corrado Fischer C-Box for Tapes: £15
2 x Corrado Rear Wiper arms: £5 each
Corrado Fuseboard cover with good condition clips: £15
Corrado Steerring Column Cowling, both Parts: £20
Corrado Inner Arches: £15 the Pair
Do you happen to have the drivers side speaker cover from the door card?
Thanks.
Went with the interior I'm afraid
Steve, depending on my gluing skills I may need a tailgate central lock pump actuator if you have one. I snapped a bit off pulling the spoiler out at the weekend.
the tailgate at mo is complete.
Bits that have Sold:
*Headlining & sunroof seal
*Mk4 Rear Calipers
*Grill & badge
*Handbrake Cover etc
*1 x Sunroof Switch
*Unleaded switch Blank
*Courtesy Light
*Subframe
Hi Steve, just wondering if you have front window wiper mechanism. Not the blades or the motor but the arm part of it? I'm having a few issues with mine and seem to be missing a small cap and washers etc.
Hi Steve,
How much for the 16v fuel pump posted to London?
Also, you don't happen to have any coilovers for sale?
Thanks,
Kunaal
Hi, Yes I have the full wiper mech available £25 posted ok?
Hi Steve,
Thanks,
Kunaal
Hi Kunaal,
Yes I still have this, the unit is almost brand new, only done less than 2k miles and is a genuine Bosch one, cost me over £100!
The housing is a bit rusty as your imagine having been under the car for the best part of 25years, but I had no issues with it.
Are you just wanting the pump or the full unit?
Cheers
Steve
