Grrrrallye 0 Posted April 6, 2015 Is anyone running 9" rear wheels? I'm looking at Borbet A's in a staggered set of 16x7.5 and 16x9. I'm not going for a big drop, just a little, I have widened the arches. is anyone running similar with or without issues it would be good to have an idea if these are going to be grief if i ever find a set Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted April 6, 2015 Have ran 9 and currently have 9.5 depends on offset really and how much your arxhes have been pulled Quote Share this post Link to post Share on other sites
swiftkid 1 Posted April 6, 2015 I ran that exact setup on my old valver without arch rolled, I run 16x9 et15 on rear on my vr with arches rolled and pulled slightly now and catches now and then but I do run it quite low Quote Share this post Link to post Share on other sites
Grrrrallye 0 Posted April 6, 2015 Sounds like i should be ok then. I do have a bit of stretch in my arches Quote Share this post Link to post Share on other sites
KeVR 10 Posted April 7, 2015 So I'm guessing 10" rears are out the question.. Been offered 10" rears and 9" front Brocks, looking through google there seems to be loads of C's and mk3 Golfs running them. If it's gonna mean massive arch work then I will keep them for the next project that should soon follow. Quote Share this post Link to post Share on other sites
swiftkid 1 Posted April 7, 2015 100% will need arch work for 10's unless you want to run it sky high. Patman on here, who recently sold his R32 Corrado was in the process of fitting some brocks in those fitments, might be worth looking for his build thread. Quote Share this post Link to post Share on other sites
Grrrrallye 0 Posted April 8, 2015 Do you guys know of anyone running Borbet A's? Been looking into these and wondering if i will need spacers on the front to clear the calipers as the et is only 20 Quote Share this post Link to post Share on other sites
Liam20vT 10 Posted April 9, 2015 My rado on borbets, I think they are et15 &pretty close to the struts. Arches have been rolled and pulled. Quote Share this post Link to post Share on other sites
Grrrrallye 0 Posted April 9, 2015 That's the look I'm after. Guessing 7.5 front and 9 rear.] Do you have any issues with caliper clearance at the front? My plan is to run 312mm breaks at the front as well Quote Share this post Link to post Share on other sites
Gwr vr6 10 Posted April 9, 2015 Liam your car looks the mutts nuts mate . Stunning on them rims . I'm putting 8.5 on tears this sat et32 I'm hoping they go on no bother Quote Share this post Link to post Share on other sites
KeVR 10 Posted April 9, 2015 That's the look I'm after. Guessing 7.5 front and 9 rear.] Do you have any issues with caliper clearance at the front? My plan is to run 312mm breaks at the front as well If I was a betting man I'd say 9j on all four corners, one of my favourite rims. They just ooze Germaness (is that even a word)... Quote Share this post Link to post Share on other sites
Liam20vT 10 Posted April 10, 2015 (edited) Cheers lads! They are 9s all round - no issues with caliper clearance although I am only running the 280mm setup. This is how it currently sits 16x9 et4 upfront & et-2 on rears :) (excuse the rusty wing, this has been replaced!) Edited April 10, 2015 by Liam20vT Quote Share this post Link to post Share on other sites
swiftkid 1 Posted April 11, 2015 I presume you all know, but just in case, the vr6 has wider track than the other models. I can't quite see from that photo but I presume you are 4 stud Liam? I'm running et15 on my vr6 and wheels poke out a fair bit [ATTACH]81298[/ATTACH] Quote Share this post Link to post Share on other sites
Liam20vT 10 Posted April 12, 2015 Your right swiftkid, I am indeed on 4 stud. Your VR does poke a lot more than mine on borbets. Nothing a bit of stretch can't sort out :) Quote Share this post Link to post Share on other sites
Grrrrallye 0 Posted April 12, 2015 Yeah, mine is a VR so yeah it will poke more but the arches have been extended but i have heard it said that I will need spacers on the front?? Quote Share this post Link to post Share on other sites
Nweaver87 10 Posted June 13, 2015 I've got 16x7.5 Borbet T's front and rear but the rear has a one inch spacer. I rub pretty hard on a decent bump but normal driving isn't so bad. I have 2 16x9 for the rear but I'm a bit scared to put them on before I roll my fenders. I seem to have a softer suspension than I should though. Quote Share this post Link to post Share on other sites
