fla
polishing foglight glass
I've got a good set of uncracked foglights but they are cloudy due to many tiny stonechips. Is there a sensible solution to removing these? Glass being as hard as it it will of course not lend itself to hand polishing so any products and methods would be appreciated.
What a Coincidence , I was thinking this last night , I have spare fogs and indicators that could do with a polish too . I was thinking of using the glass scratch remover polish , with a small palm sander . Going through the grades with wet n dry .
I tried by hand with sandpaper but didn't get too far, there was a company called Lake Country or something similar that did a glass polishing kit but the chips on the corrado glass can be quite deep so not sure how well it would work.
Apparently you cannot remove any scratches / chips which are deep enough to catch a finger nail on. Shame there's no such thing as 'glass filler' which can be sanded back!
could you use windscreen crack repair liquid, same refractive index as glass?
I'd try a 2 pack lacquer and then a flat and polish.
Stone masons who do granite worktops etc use abrasive discs to cut and shape and plaster skim poured into plastic throw away cups to set first to polish cut edges to a shine
They used to polish the edges of cut glass for furniture etc with an abrasive stone lubricated with parafin
I'll do that, I've an old spare fog and some 2K lacquer left over from my wheels, that stuff sets like concrete.
cutting oil? I got some of that for drilling holes in a stainless steel sink, although I'm favouring the 2K lacquer and flat and polish ATM :)
I wondered about that, but I thought it only became properly clear when injected into the crack under pressure, or some such?
As others have said though, a clear resin seems like a good plan!
I used glass resin to try and put a clear patch (without the fluting) on the back of a headlight glass. I couldn't get it to stay on, it kept de-laminating with heat, but I didn't try a glass etch fluid to give it some purchase, you could try that, but it won't stop the glass and resin expanding and contracting at different rates. A 2k laquer is more flexible and much thinner, so it may well work, but I'd use an etching fluid first.
Are there any led equivalents to the normal foglight bulbs to reduce heat generation that will give similar intensity and dispersion?
Well have a look at the photo here
19106099243_f9d50e35ef_c.jpgEarly corrado fog light by David0011, on Flickr
anything look odd?
half has been coated in 2k lacquer, the whole glass was pitted the same before
I'm amazed at the difference it's made, all the pitting has pretty much disappeared
19538972770_494f514644_c.jpgEarly corrado fog light by David0011, on Flickr
19731622541_aece8c8699_c.jpgEarly corrado fog light by David0011, on Flickr
19106090613_cd230944bb_c.jpgEarly corrado fog light by David0011, on Flickr
Edited by davidwort
Thats superb. The pitted portion is exactly how my fogs are so thats a good result. How do you apply 2k? Any special method?
no it's simply a 2 part mix of lacquer and hardener so chemically cures rather that's evaporating thinner, goes off in about an hour at room temperature and is far tougher than cellulose/rattle can paint, the stuff I've used was left over from a kit of vw wheel silver and lacquer that I repainted some wheels with, very tough impervious to Petrol, thinner etc once cured and sticks like the proverbial so hoping it bonds to the glass well, no reason why not, I've had old lights with over spray on them and that sticks well enough with no priming
oh, and I just used a soft modelling brush to apply it.
I've also had a go at repairing a stone damaged glass from the inside and that's looking good too
19116714354_672a265671_z.jpg20150716_075401 by David0011, on Flickr
Edited by davidwort
I think that's worth a go, it's probably cheaper than any two tin purchase online of any 2k lacquer and handy you can spray it straight on. If for any reason you get a run or dirt in it you can always flat it back and Polish it up again. I remember painting yellow tint on my mk1 spots years ago and with no prep that stayed on at least a couple of years so this is well worth a try I reckon.
I'm going to try this on some of my lenses, i seem to have a small pile of headlight and foglight glass.
