nick vr6 0 Posted June 23, 2004 Heres a new one on me. Got in c this morning and when I put my seatbelt on the section which is behind the rear panel was soaking wet. Door seals are ok, so is membrane behind door trim and rear window looks well sealed. Any ideas guys???? Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted June 23, 2004 hole in the inner rear arch? Quote Share this post Link to post Share on other sites
Phil K 0 Posted June 23, 2004 Sure it's not caused by dribbling whilst driving? :lol: Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted June 23, 2004 could it be from the sunroof drain pipe that split :? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted June 23, 2004 Is the sunroof liner on properly, or there at all? If it isn't, water will literally pour into the car. Quote Share this post Link to post Share on other sites
Reggit 0 Posted June 24, 2004 I have same problem on passenger side, had rear side window removed and resealed, this didn't solve it. Water appears to be entering from a relativley high point and running down inside of panel (under rear window) and drips onto seatbelt. Anyone know where sunroof drains are routed? I was wondering if I had a bad seal between rear quater panel and rest of car, as the windscreen people said that there was evidence that a new one had been fitted at some point of the cars life. Water only enters mine slowly, and usually in light rain/drizzle and not when absolutley belting down... strange! Quote Share this post Link to post Share on other sites
nick vr6 0 Posted June 24, 2004 Mine seems to be the same as yours reggit only wet in drizzle or light rain. When I've used pressure washer it's been bone dry Quote Share this post Link to post Share on other sites
