rado-steve
S**t F**k C**t Bo**ocks!! Slight problem with my C being Low
Feck Shit Arse C**t and a F**k load of other swear words!!!!!
Driving my rado down a country track this afternoon and hit a lump of metal embedded in the road...............
So I stopped, got out and took a look underneath, to see oil pissing out of the sump! Ooops! Then look across to the 'box and see the clutch and flywheel spinning round, remember thinking that I really shouldn't be able to see that moving :cry:
Sump not really a prob, get one from G&S for about 30squid, but my 'Box..........EeeK! Thankfully it's only ripped part of the Bell Housing Off where the shit guard bolts too...
Can you weld Alloy????? Hope so Or I need a new 'Box :x
Think it may now be a good idea to raise her up 40 or 50mm!!!!!1
Steve
that should JB weld back on... 8) Thank god that's not a vital part of the box! ;)
I'd DEFINATELY raise the suspension if I were you! ;) :?
Check all the way under the rest of the car too, you may have damaged a fuel or brake pipe and not notice until you either get a fuel leak or your brakes give up on you! :| :o
JB welding??? Is that a type of welding that welds alloy?
Can't sue the council as it was private road :(
Will get it raised when it goes to the garage, to get the sump fitted etc etc! would do it myself but I finish my 2 week hols today :mad: Typical eh?
Steve
as dazzyvr6 says, it's a type of glue... you can get it from Halfords.... It's dead easy to work and is stupidly strong when set, it'll sort that out with no problems whatsoever... 8)
  CoxyLaad said:
Pack in driving, it doesnt seem to agree with you :lol:
Think I'd agree with that!
Will try that JB Weld Stuff, Have a day off on Thursday, so off to Halfords we go!
Steve
