Rich the Chef 10 Posted November 10, 2015 Hi. I'm after some fitting instructions for an aftermarket headlamp loom. It has two genuine connectors with a wire coming off each. Which I presume are for fogs? There is the battery lead and three relays and a cluster of spade clip ends... I'll try and post a photo. But if it's similar to anything I can use as a guide I'd like to get it fitted. I just bought the car and it has a dodgy updated loom already and no dip beam! So failed it's mot today. Quote Share this post Link to post Share on other sites
Rich the Chef 10 Posted November 11, 2015 Just realised I've posted this in the wrong section. Sorry. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted November 11, 2015 sounds like you have a failed relay in the 'dodgy' loom you mention couple of £'s to fix FYI normally on an uprated loom with 2 relays if one goes you either loose main beam or dipped beam - should be an easy fix potentially however, sounds like you have a better loom to replace it with as it has 3 relays - normally one for each side dipped beam & then one for main beam uprated looms don't normally connect up to fogs. possibly the wire off each genuine connector is to loop it back into the factory loom so as the lights work off the dash switch check out my build thread as that may help, it has lots of pics of me fitting a loom made by KUR2Y on here http://the-corrado.net/showthread.php?44751-g0ldf1ng3r-s-VR-amp-1-8-16V-the-valver-has-heat!-amp-now-pokey-lights-too!/page25 Quote Share this post Link to post Share on other sites
Rich the Chef 10 Posted November 12, 2015 Thank you. 👍 Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted November 12, 2015 Thank you. no problem by all means drop me a PM if you struggle or have any questions Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted November 12, 2015 I had the same problem when i fitted an uprated loom, no sidelights, didn't bother me until mot time, i had to remove the loom, tried two different ones as well. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted November 12, 2015 I have fitted 3 KUR2Y looms now & have never had an issue with them not functioning as desired after install Quote Share this post Link to post Share on other sites
Dox 23 Posted November 12, 2015 You have to disconnect the dim - dip resistor when you fit an updated loom otherwise you can't select side lights and with the ignition on Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted November 12, 2015 You have to disconnect the dim - dip resistor when you fit an updated loom otherwise you can't select side lights and with the ignition on that would be disconnecting the yellow connectors then Dox :) Quote Share this post Link to post Share on other sites
Thursdave 10 Posted November 12, 2015 where's this yellow connector then? I fitted an uprated, two relay loom a while back but took it off quick smart as it was a choice of one dipped of the other full beam only! Quote Share this post Link to post Share on other sites
seanl82 23 Posted November 12, 2015 Should be beside the battery, behind the headlight. The resistor is bolted to the inner wing, and the yellow connectors attached to that. Quote Share this post Link to post Share on other sites
Dox 23 Posted November 12, 2015 where's this yellow connector then? I fitted an uprated, two relay loom a while back but took it off quick smart as it was a choice of one dipped of the other full beam only! It wont cure that issue anyway. Dim - dip, ignition off one click of the headlamp switch puts side lights on, 2nd click puts dipped beam on (or main beam if selected by the column switch. Dim - dip with ignition on, one click puts on dipped beam on with reduced voltage via a wire wound resistor (reduces the voltage to the dipped beam bulb), 2nd click puts on dipped beam with full voltage. Quote Share this post Link to post Share on other sites
