Bfstrachan 10 Posted February 11, 2016 Apparently chassis number dependant for which oil, so advised to check with vw for confirmation When I went to the dealers, they did recommend the green oil based on my car, but when I drained for fitting the new pump it was red that came out? Pretty sure the pump I took of was original, but can't say for definite. Thanks for the help - will look into a little more in the morning... Quote Share this post Link to post Share on other sites
Bfstrachan 10 Posted February 11, 2016 Is it distilled water you have to use with the G13 or is tap water ok? Quote Share this post Link to post Share on other sites
seanl82 23 Posted February 12, 2016 Distilled/de ionised water is better, and its cheap if you go to the diy/car isle in the supermarket. Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted February 12, 2016 Distilled/de ionised water is better, and its cheap if you go to the diy/car isle in the supermarket. top tip, cheers mate Quote Share this post Link to post Share on other sites
Bfstrachan 10 Posted February 12, 2016 Well, got everything filled and cleared out this morning. Turned the key and started up 1st time with no issues at all :) Took her out for a run and I have lovely hot air and no steering squeal! Temps look a bit on the cool side, gauge is showing around 80, when before it sat at 90. Guessing it will settle in a bit over the next few miles. I am sitting with a rather smug grin on my face - chuffed it's all worked out! Again, big thanks to all for keeping me right along the way! Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted February 12, 2016 Well, got everything filled and cleared out this morning. Turned the key and started up 1st time with no issues at all :) Took her out for a run and I have lovely hot air and no steering squeal! Temps look a bit on the cool side, gauge is showing around 80, when before it sat at 90. Guessing it will settle in a bit over the next few miles. I am sitting with a rather smug grin on my face - chuffed it's all worked out! Again, big thanks to all for keeping me right along the way! winner winner chicken dinner!! Quote Share this post Link to post Share on other sites
Bfstrachan 10 Posted February 12, 2016 Just got it in for its MOT. Looks like it failed on a dash bulb for the main beam (blue one) not working! Off all the things to fail on... So, any pointers on how to replace it. Please tell me I'm not taking the dash to bits again! Quote Share this post Link to post Share on other sites
Wullie 1 Posted February 13, 2016 This guide should help. http://the-corrado.net/showthread.php?46064-How-to-change-blub-in-instrumental-panel Quote Share this post Link to post Share on other sites
Bfstrachan 10 Posted February 13, 2016 This guide should help. http://the-corrado.net/showthread.php?46064-How-to-change-blub-in-instrumental-panel Thanks! That certainly looks doable :) Was dreading taking the dash to bits again, but will give this a go. Any idea where to get the bulbs from? Quote Share this post Link to post Share on other sites
Wullie 1 Posted February 13, 2016 Not sure where you could get them from, possibly VW. I had some kicking about. The blue one was actually a smaller white one with a blue cap over it. se a screwdriver with a magnetic tip though while you are doing it, you don't want to drop a screw down the dash. Wullie Quote Share this post Link to post Share on other sites
Wullie 1 Posted February 13, 2016 [ATTACH=CONFIG]83195[/ATTACH] This is what they look like when unclipped from the panel. Maybe help. Quote Share this post Link to post Share on other sites
Bfstrachan 10 Posted February 13, 2016 Thanks, will give the dealer a phone on Monday to see if they still stock them. Quote Share this post Link to post Share on other sites
Bfstrachan 10 Posted February 15, 2016 Well, dealer said the bulbs were discontinued last year and there are no old stock to be found either :( What has everyone done to remedy this - are there any alternatives? Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted February 15, 2016 id whip the bulb out & see if its a common size or if a common size will fit. ideally blue bulb or blue LED Quote Share this post Link to post Share on other sites
Bfstrachan 10 Posted February 16, 2016 [ATTACH=CONFIG]83195[/ATTACH] This is what they look like when unclipped from the panel. Maybe help. Managed to get the bulb out and yes it's blown. Does the beige plastic holder need to come out for fitting the replacement? Tried to refit the old one, just to see how the replacement would go back in and didn't go well. That was with the holder still in the clocks, which makes me think I need to take it out for refitting? Quote Share this post Link to post Share on other sites
Wullie 1 Posted February 16, 2016 I took the beige and black parts out as one unit then separated them afterward. The bulbs have to be connected the right way and have one leg with a bend in it to assist this. I reassembled the unit and replaced it as a whole. The bulbs/diode thingys I had lying about, I had picked them up on a visit to a scrapyard at some point. Maybe Maplins or someplace like that could help. Quote Share this post Link to post Share on other sites
Bfstrachan 10 Posted February 16, 2016 I got a little spooked when I tried to remove the beige part as the blue plastic backing with the circuits seemed to be preventing it from coming away cleanly? Do I just keep pulling till they separate? Thanks! Quote Share this post Link to post Share on other sites
Wullie 1 Posted February 17, 2016 It is held in with a clip at either end 5of 2th5e bei20ebit.If you look at the image you will see what I mean. Push them in as you remove it and it should come free. Quote Share this post Link to post Share on other sites
