stuarttaylor37 13 Posted January 30, 2016 Hi I will post pictures tomorrow but was wondering if corrosion on the front sills at the front wheelarch and crushed front jacking points is very expensive to have fixed? Quote Share this post Link to post Share on other sites
seanl82 23 Posted January 31, 2016 It's quite common Stuart, but it depends how far the rot goes. What you see isn't always the full extent as it travels under the underseal so it'll have to be ground off to get a true reflection. If you can remove your wheel arch, carpet, and any trim surrounding the affected areas it'll be easier (cheaper) for a welder to do. I'd imagine it would be a couple of hundred for both sides to be cut out and new metal welded in. Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted January 31, 2016 Thanks Sean, Here's the photos (sorry about the quality but hopefully you get the idea Quote Share this post Link to post Share on other sites
seanl82 23 Posted January 31, 2016 The leading edge of the sills where it meets the front wing will absolutely need to be cut out. The rest doesn't look too bad though, you may be able to get away with grinding it back a bit as it looks mostly on the surface, then putting a bit of paint on before underseal mate. I've seen far worse so wouldn't stress too much. Worth getting it done sooner rather than later though as especially if you're using it in this weather, the water will get in between the exposed metal and the current underseal and spread like wild fire. Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted January 31, 2016 Thanks again Sean I have never had welding/bodywork done on a car before and was worried it was going to be really expensive I'm going to take it to a body shop and get a quote this week, it needs doing sooner as you say though its in my TDI daily so is getting further seasoning with the salt going down the mo! Quote Share this post Link to post Share on other sites
dr_mat 0 Posted February 1, 2016 Cue: "when I were a lad .." But it's true, when I were a lad cars 6 years old routinely needed welding it was a widespread and common practice. Now we're seeing Corrados reaching 25 years+ and they're only now starting to show up under the torch .. How far have cars come! Quote Share this post Link to post Share on other sites
eugopnosaj 0 Posted February 2, 2016 Mine failed on this at its last MOT, needed to cut a small section out and make a repair, easy enough to do, the only difficult bit is if you have to cut a part of the wing out like I did where the angle changes slightly so the replacement metal needs to be a bit creative to get the shape back. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted February 3, 2016 one side of my VR had this done last year I got sill repair panels from VW Heritage, took about 4 weeks to arrive as they got them from classic parts in Germany sill outer part numbers... LHS 535809839A RHS 535809840A Quote Share this post Link to post Share on other sites
Gti_Jamo 10 Posted February 3, 2016 Mine was like that., but yours looks worse. I ended up having to chop out about 10 inches of the sill, inner sill and a section of the floor to fix it properly. Managed to cut a section of sill further back out a donor car and use that to get the correct shape for the sill and just fabricated the rest. Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted February 3, 2016 Thanks all, had a local garage quote £250 a side to pull the floor straight and fab up the sill pieces, just waiting for a response from a bodyshop that specialises in classics Quote Share this post Link to post Share on other sites
