CazzaVR
Misc Parts inc Arch Liner, ABS ECU's, Trim, Badges etc etc
All prices + postage. Happy to combine postage :)
Pair of boot strut dampers inc fixings. Good working order: £15
24563627445_389b495b76.jpg1 x boot struts and all parts by vornwend, on Flickr
Heater fascia panel inc 3 adjuster knobs: £30
23935464994_527d74d662.jpgHeating panel and knob and light by vornwend, on Flickr
Front wheel arch liner (think it's passenger side), good condition: £15
24481326981_59211115c1.jpgP1150025 by vornwend, on Flickr
Rubber scuttle seal: £5
Rubber bonnet seal: £5
24455316062_4867ce3311.jpgP1150024 by vornwend, on Flickr
Steering knuckle (removed from 2.0 16v): £10
Throttle cable (2.0 16v), good working order, inc bulkhead grommet: £5
Fuel filler surround piece, good condition: £5
24455318092_e36a0b3062.jpgP1150023 by vornwend, on Flickr
Radiator air guides (2.0 16v), excellent condition: £20
24268106340_a90ca194a7.jpgAir guides by vornwend, on Flickr
Footwell kick plate (black): £5
Coat hook (black): £2
Relays 79/179: £1 each
24455324802_008caba009.jpgDriver footwell plastic?, Indicator stalk, Coat hook, Fuse 79, Fuse 179, rubber gommets by vornwend, on Flickr
Intake pipe (2.016v), good condition: £10
Injector (cold start?) 2.0 16v: £5
24481340501_1bddebff6f.jpgFuel injector pipe?, HT lead cover? by vornwend, on Flickr
Glovebox trim strip, intact!: £10
Upper steering cowling (adjustable column): £7
Steering height adjust handle: £3
23936831313_89e9e8a55a.jpgFuse box, 2 x roundels, steering adjustment lever? Steering housing, Door pin, glove box plastic trim by vornwend, on Flickr
Driver's undertray (black): £10
24537478926_674c7debef.jpgDiver underside tray by vornwend, on Flickr
2.016v brake booster: £7
24481347571_9278de2333.jpgBrake cylinder by vornwend, on Flickr
24537484626_20b0d6f778.jpgBrake cylider by vornwend, on Flickr
Steering column piece: £7
23935494234_ac2f236b6f.jpgSteering rack by vornwend, on Flickr
Edited by CazzaVR
Ayup mate, I've received the FRONT vw badge instead of the rear!!
And I have a rear instead of a front!
PM me your address if you want to swap and i'll do the same
Lol! Sorry chaps, my elderly business partner got confused during the packing :lol: Let me know the postage costs and I'll refund you both ;)
Posted it today first class so should be with you on monday.
Guest sam1990rhodes
hi mate, have you got the fuse box cover/clips?
Guest sam1990rhodes
what about the clip that holds the bonnet release cable to the latch by your knees in the car?
