culshaw 1 Posted March 12, 2017 and she's out! Quote Share this post Link to post Share on other sites
Geeba 0 Posted March 13, 2017 Nice! Just in time for the nicer weather - more pics! Quote Share this post Link to post Share on other sites
culshaw 1 Posted March 29, 2017 Car has just got a new MOT, at the cost of a new CAT and a steering rack (got one from powerracksdirect for £145). Should be getting it back next week. I was really worried about how low it would sit at the back on 17's but it seems not too bad right now. It might have helped that I have taken everything but the spare wheel out though! Quote Share this post Link to post Share on other sites
culshaw 1 Posted May 10, 2017 Got her back after what seems like an eternity! Sent from my Nexus 5X using Tapatalk Quote Share this post Link to post Share on other sites
culshaw 1 Posted May 30, 2017 So tonight I thought I would see if I could slide the sunroof backwards with the allen key. It was a little tough at first but I managed to get the sunroof halfway slid back with a wind unwind rocking motion. The guides are completely caked in what I think is dried up lubricant. I'm happy it slid back at all tbh, I thought it was shot. I'm going to try to order some lubricant in the morning to free up the mechanism. One problem I did have though was that the trim seemed to be further back than the actual roof panel. It only happens on slide back though. Pics for 1000 words if anyone can confirm if this is the expected position upon opening? Quote Share this post Link to post Share on other sites
culshaw 1 Posted June 15, 2017 Spruced up the engine bay a little bit today, meant to get the old foam off but ran out of time. Quote Share this post Link to post Share on other sites
culshaw 1 Posted September 7, 2017 Found this, this morning. No idea what has caused it, could be heat. Annoyed! Quote Share this post Link to post Share on other sites
coullstar 0 Posted September 7, 2017 Normally a small impact would have cracked the paint. Quote Share this post Link to post Share on other sites
culshaw 1 Posted September 7, 2017 coullstar said: Normally a small impact would have cracked the paint.Yea but that definitely hasn't happened car has been on my drive for months And in other news I'm so dumb I was operating the sunroof switch completely wrong and I now have a working sunroof!!! My two remaining electrical niggles are no stereo and electric mirrors. Quote Share this post Link to post Share on other sites
culshaw 1 Posted April 10, 2019 Stripped the front-end, replaced all the coolant hoses with Samcos. Treated the rad support, it wasn't in terrible condition but a layer or two of hammerite will help it Also dug out my ambitious next step but am nervous about strapping it on and blowing up the engine given it's done 150k after 3000rpm. There's a metal prong welded on (you can see on far-right). I'm unsure what this is for, it doesn't seem to fit anywhere on first glance. Quote Share this post Link to post Share on other sites
Simeon 0 Posted April 10, 2019 Nice motor :) that'll certainly liven up the VR! Get it on there Quote Share this post Link to post Share on other sites
culshaw 1 Posted April 10, 2019 Simeon said: Nice motor :) that'll certainly liven up the VR! Get it on there Absolutely pappin' about it going on! :) Quote Share this post Link to post Share on other sites
culshaw 1 Posted May 6, 2019 Today I rounded off a whole series of work I've been doing on the car I've fitted samcos, a metal crack pipe, an oil cooler and started the plan for supercharging I used a setrab cooler bracket to house the mocal (the mocal needed a bit of help to fit) and then drilled two holes in the slam panel centre pillar to mount it. I'd previously measured this up and planned it but didn't allow for pressure under the slam panel when it is tightened to the chassis. This means it's a very very tight fit against the rad on the bottom left. Tighter than I'm happy with. Here's how it looks fitted After this photo I looped some broken plastic around the upper pipe as a makeshift sheathing to stop the razor sharp metal on the slam panel cutting into the pipe. (Temp bodge) Earlier on in the day i'd had the bright idea of turning the engine on while the oil cooler was disconnected but pipes were dangling. It could have been an expensive mess given I'm in rented housing, but I had a tiny spark to put the pipes into a bucket. It ended up with 1.5ltrs of oil in so I got super lucky. I was under the impression the thermostat wouldn't open until 80deg so was really surprised to see any oil! Quote Share this post Link to post Share on other sites
GrahamU 6 Posted May 7, 2019 Nice fitment. Is your filter take off thermostatically controlled ? you may find the oil runs quite cold with it there. Quote Share this post Link to post Share on other sites
culshaw 1 Posted May 7, 2019 rado20vT said: Nice fitment. Is your filter take off thermostatically controlled ? you may find the oil runs quite cold with it there. Yes, it's supposed to open at 80 degrees, I was mystified to see a bucket full of oil Quote Share this post Link to post Share on other sites
fendervg 33 Posted May 7, 2019 Looking good - what are the plans with the super charging? I was always tempted to fit a small oil cooler myself on the N/A car to keep the temperatures down to more acceptable levels (88-100 would be nice!) - I wonder if renewing the heat exchanger would improve things... Quote Share this post Link to post Share on other sites
Bauhaus 3 Posted May 7, 2019 culshaw said: Yes, it's supposed to open at 80 degrees, I was mystified to see a bucket full of oil Nice tidy install. As for your bucket of oil test... unless its specifically stated by the manufacturer.. 80 degrees means its fully open at 80 degrees, so some oil will flow when cold. Quote Share this post Link to post Share on other sites
culshaw 1 Posted May 16, 2019 I've been mulling over in my head whether there would be more clearance on the opposite side of the slam panel to give a better fit. I tested it out and I estimated there was about 3cm more depth so got to drilling and mounting. Here's after a test mount, before I laid down some new shiny pipes. Pipes going out sandwich routed to base of crossmember. They sit nicely to the edge of the rad. Mounted and piped, quite happy with the length, I think the lower pipe is around 5-6cm too long but it's no big deal. Sits nicely behind bumper Quote Share this post Link to post Share on other sites
Bauhaus 3 Posted May 17, 2019 Nicely done, looks the business Quote Share this post Link to post Share on other sites
culshaw 1 Posted May 30, 2019 Ran the car up to temp to try and get the thermostat to open after reassurance from the bloke who sold me the mocal, realised too late I hadn't put a retaining clip back on a thermostat sensor, cue coolant acid rain. Hopefully will get it back together and topped up tonight Quote Share this post Link to post Share on other sites
culshaw 1 Posted August 23, 2019 Car is back together, seems to be working all fine. I have replaced a faulty ABS sensor, fixed a broken bonnet cable clip, and also fitted the Kurzy loom I've had since 2015. Car is almost ready for MOT. Then supercharging. Also picked up some used Eibach springs for a mk2 golf that stand higher than the supposedly "correct fitment for a corrado b12 kit springs". I'm not buying it but whatever. It's over now. Quote Share this post Link to post Share on other sites
culshaw 1 Posted September 4, 2019 New wheels, no more spacers! This is the first picture of the ride height sorted with the mk2 eibach springs (on a bilstein b12 setup) Quote Share this post Link to post Share on other sites
_Matt_ 32 Posted September 4, 2019 (edited) Looking good. I've got the B12 kit too (with the revised rear springs). Did you fit the original rears? I didn't bother as new they'd be wrong looking the size of the spring. Edit - now seen your previous pics and see you did have it fitted. New setup is much better imo - gaps looks consistent front and back. I reckon the original springs in the eibach kit were really for the -50mm sportline kit. Edited September 4, 2019 by pfnsht Quote Share this post Link to post Share on other sites
ben_wooduk 0 Posted September 4, 2019 I like the look! 16's? Quote Share this post Link to post Share on other sites
ChrisL 20 Posted September 4, 2019 Good choice. I like them. Quote Share this post Link to post Share on other sites
