EJ Taylor
The One With the "Sun Roof" Delete has popped back up.
http://www.ebay.co.uk/itm/Volkswagen-Corrado-VR6-1993-full-rebuild-fast-road-high-spec-px-/182191774858?hash=item2a6b79dc8a:g:mIAAAOSwuzRXdvMV
"" The engine has had a significant amount of work carried out by the previous owner about 8 months ago, with receipts to prove.
Head was fully stripped, pressure tested, skimmed and rebuilt new valve stem seals and valves re sat.
New gaskets throughout
New crank oil seal
New top timing chain tensioner and chain guides
New water pump
New injector seals
New oil, filter, coolant etc
Gearbox was removed and painted ""
Yer we call that a service mate....
It's got whistling windscreen glass too. That's quite rare
MATE..... WHO fitted that windscreen, for gods sake :lol: :lol: :lol: :lol:
Just saw this " The paintwork is the only thing that lets this car down from being a real show-stopper,"
Tbh, bit of T-cut i recon it could go in a VW museum?
That repair to the sunroof looks like a factory option.
Looks like? i thought it was? I was going to go to VW later and ask if they still do the panel and pop rivet kit?
Guest sam1990rhodes
I wonder how the 'delete' looks from the inside, can imagine there's just a massive hole in the roof lining.
has to be fine right, after all, its only the paintwork which lets the car down
DUDE!
The paints the only thing holding it back from being a real show stopper. He said that himself. Not to mention to EXTENSIVE engine work.
Its piratically had a full restoration. I thought VW had done a reproduction when i first saw it
Guest sam1990rhodes
Paintwork being code for car?
Guest sam1990rhodes
DUDE!Not to mention to EXTENSIVE engine work
Is that why he means by putting it back in on the p iss?
New crank oil seal
New water pump
New injector seals
To be fair thats a lot more than a service. Would make a perfect base for a track car with all that done. Sunroofs are rubbish anyway. They weigh a lot, leak and break. A moonroof is only acceptable option I think other than not having one IMO.
I agree on the good basis for a track car - to rip out the running gear and drop into a Mk2 Golf ;)
