KARMANN
Handbrake light intermittently going on and off
Today whilst driving my handbrake light started to go on and off, most when cornering or hitting bumps. Most probably a loose connection. But i was wondering if that light is used for anything else, ie to highlight another fault.
It still works as should when operating the handbrake.
Any suggestions?
Fraser
Ahh, ill check that! As when i was sitting stationary without the handbrake on and pumped the brakes it flickered a few times! Top man Sean-i shall report back.
Fraser
Low brake fluid... if it appears low and the pads are not worn / due for a change then suspect one of the clutch components is leaking.
Look for signs of brake fluid on top of the gearbox (under the clutch slave)
Had a quick check of the brake fluid this morning before i left for work. It’s just below the minimum. So that’ll be the reason why. Now to find out where it has gone-ill check those areas for fluid.
Fraser
dont top it up until you've checked both the front and back brakes. If they're all ok, then look for leaks and topup accordingly
