robrado974 1 Posted August 4, 2019 In good condition please ,i just need the bee sting part . kind regards Rob Quote Share this post Link to post Share on other sites
Keyo 47 Posted August 4, 2019 (edited) Put in VW golf corrado aerial antenna mast genuine OE into ebay search. cost is£14.95 + postage Worth going for an original Hirschmann which will be stated in the item description on ebay. The forum wont allow me to post the link mate as it's still not working. Had an aftermarket on mine and the Hirschman made the signal perfect on all frequencies don't bother with cheaper copies. Edited August 4, 2019 by Keyo Quote Share this post Link to post Share on other sites
robrado974 1 Posted August 4, 2019 Will take a look , thanks Keyo . Quote Share this post Link to post Share on other sites
robrado974 1 Posted August 4, 2019 That’s the twist antenna isn’t it ?. Quote Share this post Link to post Share on other sites
vw rule 19 Posted August 4, 2019 Hi Rob, as Keyo has mentioned above EBay item number is: 171216178792 Says in the sellers advert that, This mast has a length of 410mm (16" inches) with a flexible black rubber sheathed coil around the whip, i.e bee sting. It has a fixed 5mm diameter male thread which is 7mm in length. Hirschmann replacement mast as supplied to VW/ VAG by the Original Equipment (OE) according to the EBay seller. Cost £14.95 + £3.25 postage States they only have limited stock available so possibly have 12 to 20 max left ? Rob I've sent you a text message of the above just in case the forum starts playing up again. Si Quote Share this post Link to post Share on other sites
robrado974 1 Posted August 4, 2019 Yep got it , thanks Si . Quote Share this post Link to post Share on other sites
vw rule 19 Posted August 4, 2019 No worries mate. Si Quote Share this post Link to post Share on other sites
robrado974 1 Posted August 4, 2019 (edited) I knew I had a spare somewhere. I’ve dug it out . The antenna measures 16.5”. If these are Oem am I right in saying the one I have is not Oem . I can’t put pics up anymore. I will text a pic Si. The new one fits on ok but when tight is the wrong angle . Edited August 4, 2019 by robrado974 Quote Share this post Link to post Share on other sites
Keyo 47 Posted August 4, 2019 Thread sounds bent in the aeriel, spoil yourself to a new un why you can still get one. Quote Share this post Link to post Share on other sites
ChrisL 20 Posted August 4, 2019 Can you buy the whole aerial still including base and gasket or are they the same as newer golfs? Quote Share this post Link to post Share on other sites
vw rule 19 Posted August 4, 2019 Rob I bought an aerial new from VW main dealer, think it was £56 for the whole kit back in 2006 From memory I think the bee sting mast is 41cm (410mm) as standard, I'll measure mine and let you know as it's the original stock item. Regarding the wrong angle Rob it could be as Keyo has mentioned, the small 5mm male stud could be bent slightly. I'm on WhatsApp Rob if you need to send a photo, as it's free as long as you have WiFi Si Quote Share this post Link to post Share on other sites
vw rule 19 Posted August 5, 2019 ChrisL yes I believe you can still purchase the whole aerial as a kit, but they are starting to be a little rarer now. Best bet is EBay or Amazon, you could try the main dealers but it's probably obsolete now. I think the Corrado aerial was used up until roughly 2007 on other VWs then they changed slightly. On my old MK3 Polo that I used to have, that had pretty much the same aerial set up as our Corrado's. Si Quote Share this post Link to post Share on other sites
robrado974 1 Posted August 5, 2019 So did the original antennas come with the twist or just straight?. Just curious. Quote Share this post Link to post Share on other sites
fendervg 33 Posted August 5, 2019 The original ones all had the twisted wire on the outside - they were common on all the Mk2/Mk3 era cars that had an amplified base. You can also get a shorter bee sting type that had no twists, this is what I have on my car - you lose a little bit of reception but it looks sleeker and more modern. Quote Share this post Link to post Share on other sites
robrado974 1 Posted August 5, 2019 I have the shorter one at the moment, the wire twist isn’t as pronounced as the other one I have . Quote Share this post Link to post Share on other sites
vw rule 19 Posted August 5, 2019 Rob I've had a look and measured my original aerial and it's definitely 410mm or 41cm (16") long. That's measuring from the base of aerial to the end tip, but not including the 5mm stud. Sent you a text as well. Si Quote Share this post Link to post Share on other sites
vw rule 19 Posted August 5, 2019 That new aerial you've fitted looks miles better Rob :thumbleft: Si Quote Share this post Link to post Share on other sites
robrado974 1 Posted August 6, 2019 Thanks Si. Obviously I’m used to seeing the old one , so the new one looks a little odd at the moment. I will get used to it . Thank you for everyone’s input. Kind regards Rob. Quote Share this post Link to post Share on other sites
