ChrisL
Moonlight Blue VR6
An outstanding refurbishment,  which is only to be expected by you. Pushing it to the next level as always, looks fantastic 👌
Made a start on sorting the engine. The last major job before the final re-assembly ready for next year.
Got the back of the block cleaned and painted and also got some of the aluminium parts blasted and painted.
Amazing attention to detail as always. I need to find someone that can do this near me
Edited by Cressa
6 hours ago, Cressa said:
Amazing attention to detail as always. I need tonfind someone that can do this near me
Thanks, I’ve got loads more to plate.
if you are stuck I can always sort it for you.
An engine good enough to match your engine bay. Keep it going💪
23 hours ago, KIPVW said:
Looking Fantastic Chris 🥰
Cheers Kippy, in your expert opinion, am I over restoring the car should I ever decide to enter it at somewhere like Stanford?
  • Like 1
Cheers mate
Hi Mate,
It's a difficult balance isn't it. The work you are doing can be seen as a little excessive and being a little too much but in reality you are just presenting metalwork a lot closer to how it looked originally but with a better finish than it had at the time.
There will always be some that will say one thing or another but if the presentation is sympathetic to how it used to look I would personally prefer that.
Keep it up mate it's looking fantastic. 👍
On 9/21/2023 at 12:51 PM, ChrisL said:
Just to keep the updates coming.
heater matrix all sorted and dash back in along with the re-trimmed steering wheel and new gearknob.
Hi,
Can I ask, what did you do about the dash area wiring where most of the harness sponge tubes had dis-integrated, did you re-loom with felt tape or what, to avoid potential noises inside the dash ?
I took all the foam off and wrapped it in wiring loom tape which is a bit like felt stuff. It’s all clipped in well so shouldn’t rattle
Right, thanks for that, just wondered.
