Keyo 49 Posted December 18, 2019 Anyone got a failing MFA display screen ? Below link has the repair. Came across this company in Germany whilst looking for some gear cog wheel for my mechanical odometer on my Golf- just need to determine how many cogs it has I think 21. Here is the screen. https://www.ebay.co.uk/itm/DISPLAY-FUR-VW-CORRADO-53I-PASSAT-35I-T4-MFA2-BORDCOMPUTER-KOMBIINSTRUMENT-VDO/173961555902?fits=Model%3ACorrado&hash=item2880eaafbe:g:8nUAAOSwPa9dpuXM Quote Share this post Link to post Share on other sites
fendervg 33 Posted December 18, 2019 Good find - the later ones rarely go bad from what I have seen so far, touch wood. I think it's more related to a voltage spike or faulty regulator, and this then damages the MFA and LCD. Quote Share this post Link to post Share on other sites
Keyo 49 Posted December 18, 2019 fendervg said: Good find - the later ones rarely go bad from what I have seen so far, touch wood. I think it's more related to a voltage spike or faulty regulator, and this then damages the MFA and LCD. Wish I had found it earlier I forked out £200 and something for a new binnacle circuit last year from Classics! From memory though they only had the Golf MK2 available when I looked so a new product on the market, think I might still buy one as have the old unit still so will be a good spare. My old one the first digit would only show half the number intermittently so I guess it was starting to fail. Quote Share this post Link to post Share on other sites
fla 9 Posted December 18, 2019 Sometimes the conductive rubber strips move from the board causing the display to fail. You can remove, clean and replace Quote Share this post Link to post Share on other sites
Keyo 49 Posted December 18, 2019 fla said: Sometimes the conductive rubber strips move from the board causing the display to fail. You can remove, clean and replace I was hoping that was my problem but unfortunately it did not resolve it. Quote Share this post Link to post Share on other sites
robrado974 1 Posted December 18, 2019 fla said: Sometimes the conductive rubber strips move from the board causing the display to fail. You can remove, clean and replace Yeah this happened to me Hassan, when I took it apart to go back to OEM green. The MFA is fine , but the rubbers moved on the other screen, I tried so hard to get it all slotted in nicely, but I ended up with said screen very slightly less brighter than the MFA one . Quote Share this post Link to post Share on other sites
