ABV-VR6 12 Posted January 10, 2020 (edited) Sorry guys for asking another wheel question... In my quest to find a replacement for the schmidt I tumbled across a set of JDM BBS wheels that looks very similar to the LM's but in 16". LM's have always been my all time favorite but I don't want to run 17". Anyways to come back to the subject the wheels have a center bore of 56mm and the Corrado has 57.1mm, does that mean they wouldn't fit? I'm thinking they won't but would like to confirm with the pros :thumbleft: Thanks again cheers Edited January 10, 2020 by ABV-VR6 Quote Share this post Link to post Share on other sites
seanl82 23 Posted January 10, 2020 No they won't. If they were larger you could get spigots to fill the difference, but uour only option would be to get them bored out to 57.1 Quote Share this post Link to post Share on other sites
ABV-VR6 12 Posted January 10, 2020 Okay, thanks again Sean! That's too bad, they were so nice. I'm not having a good luck with wheels it looks like! Quote Share this post Link to post Share on other sites
seanl82 23 Posted January 10, 2020 Most machining companies would be able to do it. No real idea on how much it would cost though.... Quote Share this post Link to post Share on other sites
Dox 31 Posted January 11, 2020 It’s been done several times carefully with a drill and bobbin sander. Subaru usually have a higher offset so need spacers to clear the struts Quote Share this post Link to post Share on other sites
ABV-VR6 12 Posted January 11, 2020 It’s been done several times carefully with a drill and bobbin sander. Subaru usually have a higher offset so need spacers to clear the struts Yes they are Subaru's! I did noticed the offset at 48et but like you said with spacers it would have been fine. The center bore though, I'm not sure I want to play with that... That's too bad, they are fantastic and light. It's these ones I was thinking about, I would have done a silver powder coat: https://forums.nasioc.com/forums/showthread.php?t=2774070 Quote Share this post Link to post Share on other sites
Keyo 49 Posted January 11, 2020 Depends how much you want to spend but for many the most sort after alloy is the BBS RS 5 stud. Think they go for between 2k-3k though ! There are replicas knocking about though. Quote Share this post Link to post Share on other sites
ABV-VR6 12 Posted January 11, 2020 Depends how much you want to spend but for many the most sort after alloy is the BBS RS 5 stud. Think they go for between 2k-3k though ! There are replicas knocking about though. Thanks Keyo for the suggestion. I personally like the BBS RX but they are rare to find as well. Still in the used market though. Too bad that wheel sizes changed so much over the years, looking for new ones they're all in the 18/19/20 sizes now... The hunt continues I guess! Quote Share this post Link to post Share on other sites
Keyo 49 Posted January 11, 2020 (edited) I have a set of BBS RX2 they are a great alloy and direct fir. I also have BBS RS 771 or known as the anniversary split rim alloy these are easy to get hold of and priced in the £300 mark in the UK. Basically they are a split version of the BBS RX and came on Mk3 and MK4 golf anniversary cars. Both 16 and 6,5 J or 7J 5 stud direct fit. You can see the RS771 on my car black magic http://the-corrado.net/showthread.php?109949-Black-magic-returns-home/page6&highlight=black+magic 25 mm lowering springs Tyres 205/45/ R16 Edited January 11, 2020 by Keyo Quote Share this post Link to post Share on other sites
Dox 31 Posted January 11, 2020 Yes they are Subaru's! I did noticed the offset at 48et but like you said with spacers it would have been fine. The center bore though, I'm not sure I want to play with that... That's too bad, they are fantastic and light. It's these ones I was thinking about, I would have done a silver powder coat: https://forums.nasioc.com/forums/showthread.php?t=2774070 I looked into having custom spacers made but due to the length of the boss on the rear disks they would have to be 25mm plus otherwise the centring boss on the spacer is prone to shearing off due to lack of material on the spacer. Redborbet / redborbon a user on here has opened up a few sets of Subaru fit wheels and they’ve looked great in the pics he’s posted in his build thread. Quote Share this post Link to post Share on other sites
ABV-VR6 12 Posted January 11, 2020 I have a set of BBS RX2 they are a great alloy and direct fir. I also have BBS RS 771 or known as the anniversary split rim alloy these are easy to get hold of and priced in the £300 mark in the UK. Basically they are a split version of the BBS RX and came on Mk3 and MK4 golf anniversary cars. Both 16 and 6,5 J or 7J 5 stud direct fit. You can see the RS771 on my car black magic http://the-corrado.net/showthread.php?109949-Black-magic-returns-home/page6&highlight=black+magic 25 mm lowering springs Tyres 205/45/ R16 They look fantastic mate! Thanks for all that great info. I may start looking to get these, I like the straight fit and oem look. Cheers and have a good weekend! Quote Share this post Link to post Share on other sites
ABV-VR6 12 Posted January 11, 2020 I looked into having custom spacers made but due to the length of the boss on the rear disks they would have to be 25mm plus otherwise the centring boss on the spacer is prone to shearing off due to lack of material on the spacer. Redborbet / redborbon a user on here has opened up a few sets of Subaru fit wheels and they’ve looked great in the pics he’s posted in his build thread. Oh I'm sure they look good! But it's starting to e too much work and money involved to make it happen. If the rims were super cheap it would maybe make sense but they are not cheap to start with... Thanks for your reply! Quote Share this post Link to post Share on other sites
Keyo 49 Posted January 11, 2020 They look fantastic mate! Thanks for all that great info. I may start looking to get these, I like the straight fit and oem look. Cheers and have a good weekend! No worries mate did you get the Golf anniversaries in Canada ? Quote Share this post Link to post Share on other sites
ABV-VR6 12 Posted January 11, 2020 No worries mate did you get the Golf anniversaries in Canada ? Oh I though you were selling me yours just kidding! I think so mate, I'll check locally or on ebay I think I'm gonna go for them and have them powder coated light grey with silver lip. Should look sharp on my silver Corrado! Cheers! Quote Share this post Link to post Share on other sites
Simeon 0 Posted January 13, 2020 Yes they are Subaru's! I did noticed the offset at 48et but like you said with spacers it would have been fine. The center bore though, I'm not sure I want to play with that... That's too bad, they are fantastic and light. It's these ones I was thinking about, I would have done a silver powder coat: https://forums.nasioc.com/forums/showthread.php?t=2774070 As Dox has said, flap wheel on a drill, takes about 5 mins per wheel with the double checking every so often as you are literally removing a fraction over 0.5mm all around. Dead easy, even I've done it (on a set of Subaru wheels too as it happens) Quote Share this post Link to post Share on other sites
ABV-VR6 12 Posted January 13, 2020 Thanks for your reply, you know I haven't seen that, that way, but it's true not so much to remove... You haven't felt any unbalanced with the wheels after? Do you have the same ones that are on the link I posted? Do you happen to know if Subaru's used ball lug nuts like VW for their wheels or you had to change them? Quote Share this post Link to post Share on other sites
Simeon 0 Posted January 13, 2020 Thanks for your reply, you know I haven't seen that, that way, but it's true not so much to remove... You haven't felt any unbalanced with the wheels after? Do you have the same ones that are on the link I posted? Do you happen to know if Subaru's used ball lug nuts like VW for their wheels or you had to change them? No it was a different set of alloys, I used them as winters for a few months. Pretty sure I used tapered bolts (few years ago now) and no never had any wheel wobble etc. I did offer them up to the hub frequently to make sure I wasn't taking too much off. Quote Share this post Link to post Share on other sites
Dox 31 Posted January 13, 2020 I have 2 sets of Subaru wheels, 16" OZ crono off an Imprezza that wont fit on the VW hub and a set of 16" make unknown (they look similar to OZ mito) off a Forrester which have a centre bore larger than the C so spigots rings will be needed. Quote Share this post Link to post Share on other sites
ABV-VR6 12 Posted January 13, 2020 Ok thanks guys. So in my case though, once I remove enough materials to make it to 57.1 I should not need anything else other than new head bolts probably and a set of spacers because they're et48. Something like 20mm rear and 10mm front should do it. Quote Share this post Link to post Share on other sites
Simeon 0 Posted January 14, 2020 Ok thanks guys. So in my case though, once I remove enough materials to make it to 57.1 I should not need anything else other than new head bolts probably and a set of spacers because they're et48. Something like 20mm rear and 10mm front should do it. Yep, increase the CB and they will bolt straight up with the spacers and appropriate longer bolts :) Quote Share this post Link to post Share on other sites
ABV-VR6 12 Posted January 18, 2020 (edited) Sorry to be back with this again, I never paid that much attention to wheels before... So I have a friend in Japan right now that can send me a set of wheels... Looking on the auction, I found some very nice BBS RG-F that are 5x100, et35. So this time the "problem" is the center bore is 70mm. So my question is, if I was going to buy 5x100 hubcentric spacers with 70 center bore would that fix the problem? Thanks again! Edit, I found this: https://www.ebay.com/itm/Wheels-Hub-Centric-Rings-Aluminium-Alloy-OD-70-1-mm-to-ID-57-1-mm-One-Set/321735515430?hash=item4ae8ee5d26:g:2ngAAOSwtgxdmsNs Edited January 18, 2020 by ABV-VR6 Quote Share this post Link to post Share on other sites
seanl82 23 Posted January 18, 2020 Yep, that would work. Quote Share this post Link to post Share on other sites
