g0ldf1ng3r 16 Posted March 11, 2020 hi all does anyone know how the window rollers fit? the site the guide was on is no longer alive & seeing as ive got all the interior out it might be worth fitting them to get rid of the rattle thanks Quote Share this post Link to post Share on other sites
Dox 23 Posted March 11, 2020 (edited) I think I just removed the old roller with pliers, rolled the new roller down the channel and used the pliers to pinch the new roller onto the ball joint? Do one at a time to stop the lot falling into the door (worst roller first). I donated the one good roller to another forum member, the rear most roller was destroyed falling out of the channel. Edited March 11, 2020 by Dox Quote Share this post Link to post Share on other sites
fendervg 33 Posted March 11, 2020 They just pop off with a little bit of force - if they are really worn they'll nearly fall off. Then the new one just pops on - a bit of lube on the roller and the channel will help. They may not totally fix your rattle though - check that the sliding guide on the rear rail is still glued to the glass, as that is often a a major contributor if the glass has been replaced at any stage. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted March 11, 2020 thanks guys i had the drivers window mech replaced & this is when the rattle started are they easily visible when you have the door lining down? im not even sure where im looking lol Quote Share this post Link to post Share on other sites
fendervg 33 Posted March 11, 2020 There's a rail that is welded to the uprights near the bottom of the window - the rollers slide along it and are attached to the ends of the two arms attached to the window mech. The rear bracket slides up and down on the upright nearest the lock mechanism and should be attached to the window glass. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted March 11, 2020 tidy thanks fender Quote Share this post Link to post Share on other sites
Keyo 47 Posted March 11, 2020 (edited) Get some good grabber seal and inject it into the bottom of the window where it attaches- will get rid of most of the rattle. Edited March 11, 2020 by Keyo Quote Share this post Link to post Share on other sites
Cressa 44 Posted March 12, 2020 On 3/11/2020 at 6:21 PM, Keyo said: Get some good grabber seal and inject it into the bottom of the window where it attaches- will get rid of most of the rattle. What is grabber seal?😁 Quote Share this post Link to post Share on other sites
Keyo 47 Posted March 12, 2020 An adhesive seal, something that grabs - basically a very strong adhesive . Quote Share this post Link to post Share on other sites
