Crispo 0 Posted September 28, 2020 Hi everyone I've just bought my old G60 back with the hope of getting it back on the road. I sold it in 2007 and it was driven by the new owner until 2010 and then it has been off the road since. Before even trying to start it have noticed some pretty bad corrosion of the crossmember under the rad. A quick search suggests this isn't uncommon and that the part I think I need (535199171G ?) is no longer available. Can anyone confirm if this is the part I need and suggest any ideas on where to source one? I didn't expect this to be an easy or cheap project but wasn't quite ready for such a depressing start! cheers Crispo Quote Share this post Link to post Share on other sites
easypops 8 Posted September 28, 2020 Welcome along, sadly the radiator support is a very common thing to rust away, best to put up a wanted ad, there are a couple of corrado breakers out there. Chris Ferry aka Lilfuzzer. Facebook has a lot of activity and is probably a better place to locate parts. You can contact Chris through there, not sure he’s on here much these days I’d suggest you strip the front end off to be sure the front crossmember is ok as you’ll need to be in there anyway and check what else you might need. Check the wings, sills- especially at point it joins rear arch, fuel cap area as all are common rust spots 😁👍 Quote Share this post Link to post Share on other sites
Keyo 47 Posted September 28, 2020 I think these rad supports are getting thin on the ground - the sooner an aftermarket one becomes available the better- the Mk2 golf you can but all the subframes and supports aftermarket - lets hope the Corrado follows one day and they rust to heel on the rad support- leaky coolant might not help them. Quote Share this post Link to post Share on other sites
Crispo 0 Posted September 28, 2020 Cheers for the replies. I'll stick up a wanted add and check out Facebook 👍 Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted September 28, 2020 Speaking for the later ones If you’ve ever had different model ones and compared them they are all pretty much the same, the VR6 one just has a little bracket welded on. I just got a later one and welded my old ones extra bracket on. Moving on to the earlier models I’m betting if you get any early one you will be able to make it work for the G60 as they are pressed with a variety of holes not just 2 specific to your model 1 Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted September 28, 2020 I will add though, hello and welcome & The front slam panel, bit with the headlights in, Is unique to model though because of radiator size and fan/fans. It does have only two holes for radiator brackets to suit the model Quote Share this post Link to post Share on other sites
Keyo 47 Posted September 28, 2020 (edited) On 9/28/2020 at 4:31 PM, 1xshaunx1 said: I will add though, hello and welcome & The front slam panel, bit with the headlights in, Is unique to model though because of radiator size and fan/fans. It does have only two holes for radiator brackets to suit the model So Sean would that be the red one I have in my shed ? 😉 We need this skilled corrado owner to make some of the galvanised rad supports also offered in alloy. http://testforum.co.uk/viewtopic.php?t=883 From his profile his name is Rob from Durham and owned a red G60 and was making these in 2016 - his car reg was J375CAO - I wonder if his still about ! Edited September 28, 2020 by Keyo Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted September 28, 2020 On 9/28/2020 at 4:37 PM, Keyo said: So Sean would that be the red one I have in my shed ? 😉 We need this skilled corrado owner to make some of the galvanised rad supports also offered in alloy. http://testforum.co.uk/viewtopic.php?t=883 From his profile his name is Rob from Durham and owned a red G60 and was making these in 2016 - his car reg was J375CAO - I wonder if his still about ! So Kato why are you calling me Sean 😂😂 Quote Share this post Link to post Share on other sites
Keyo 47 Posted September 28, 2020 On 9/28/2020 at 5:04 PM, 1xshaunx1 said: So Kato why are you calling me Sean 😂😂 Sorry Shaun 😂 Quote Share this post Link to post Share on other sites
Crispo 0 Posted September 28, 2020 Thanks Shaun Does anyone know how much these go for when they are up for sale? I've had no luck finding one in the UK yet but have seen one in the US but it's not cheap! Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted September 29, 2020 Normally £100 - £150. 1 Quote Share this post Link to post Share on other sites
Bast 10 Posted April 7, 2021 Just to resurrect this thread. Does anyone know if a 1.8 16v support would work for a VR6? Curios what the extra bracket on the VR6 version is for Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted April 7, 2021 On 4/7/2021 at 12:35 PM, Bast said: Just to resurrect this thread. Does anyone know if a 1.8 16v support would work for a VR6? Curios what the extra bracket on the VR6 version is for ive got a feeling the rad sits differently in the VR6 compared to the 16v so that could be the reason i know the VR rad is at an odd angle will go look under the bonnet of the 16v in a tick as im in that one today Quote Share this post Link to post Share on other sites
Bast 10 Posted April 7, 2021 On 4/7/2021 at 1:12 PM, g0ldf1ng3r said: ive got a feeling the rad sits differently in the VR6 compared to the 16v so that could be the reason i know the VR rad is at an odd angle will go look under the bonnet of the 16v in a tick as im in that one today that'd be much appreciated 🙂 Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted April 7, 2021 On 4/7/2021 at 1:21 PM, Bast said: that'd be much appreciated 🙂 had a look & no the 16v rad sits at an angle as well what is the extra bracket bit you mention? Quote Share this post Link to post Share on other sites
Bast 10 Posted April 7, 2021 On 4/7/2021 at 1:28 PM, g0ldf1ng3r said: had a look & no the 16v rad sits at an angle as well what is the extra bracket bit you mention? Fantastic, thanks for looking mate. So it's something Shaun mentioned earlier in the thread. I'm not sure of it's purpose 🙂 On 9/28/2020 at 3:47 PM, 1xshaunx1 said: Speaking for the later ones If you’ve ever had different model ones and compared them they are all pretty much the same, the VR6 one just has a little bracket welded on. I just got a later one and welded my old ones extra bracket on. Moving on to the earlier models I’m betting if you get any early one you will be able to make it work for the G60 as they are pressed with a variety of holes not just 2 specific to your model Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted April 7, 2021 On 4/7/2021 at 1:51 PM, Bast said: Fantastic, thanks for looking mate. So it's something Shaun mentioned earlier in the thread. I'm not sure of it's purpose 🙂 i can check the late VR6 tomorrow for the bracket in the picture IF i can actually see it with all the bumper fitted etc if i can access it i will take some pics for you & post them Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted April 7, 2021 The bracket in the picture above is to support the VR6 radiator at an angle to the slam panel. As you can also see in the photo the basic rad support comes with loads of holes for different rads with the exception of the VR6 which needs the extra bracket welding on which I did to the one in the photo. Hope this helps Quote Share this post Link to post Share on other sites
Bast 10 Posted April 8, 2021 On 4/7/2021 at 3:10 PM, g0ldf1ng3r said: i can check the late VR6 tomorrow for the bracket in the picture IF i can actually see it with all the bumper fitted etc if i can access it i will take some pics for you & post them That's really kind of you bud, I think Shaun has answered it though. Thanks for your efforts anyway On 4/7/2021 at 5:49 PM, 1xshaunx1 said: The bracket in the picture above is to support the VR6 radiator at an angle to the slam panel. As you can also see in the photo the basic rad support comes with loads of holes for different rads with the exception of the VR6 which needs the extra bracket welding on which I did to the one in the photo. Hope this helps Ah amazing, thanks for clearing that up. Much appreciated 🙂 Quote Share this post Link to post Share on other sites
fla 9 Posted April 8, 2021 This would be great item to remanufacture - again, if we can get some CAD images i can get a mock-up and hence pricing done, for say 10, 20 and 50 off. Quote Share this post Link to post Share on other sites
