Keyo 47 Posted September 21, 2021 (edited) Hi all, On the rear beam carriers no 17 on diagram a total of 6 bolts all together part number N10141701 M10 x 25 have been obsolete fro some time. This is also the bolt that holds the front cross member - - furthest bolts to sides on the crisis member across from the bumper bracket bolts . https://www.ilcats.ru/vw/?function=getParts&market=RDW&model=COR&modelcode=76&year=1995&group=5&subgroup=500&part=106000&language=en I was wondering this vag and Porsche bolt ready available at £1.20 from Porsche has the same dimension but a different end (does not have the point ) does it matter as I would like some new bolts if the frames are coming off and I can get all the rest. N90847602 M10 x 25 Thanks gold is the obsolete bolt and silver the one available . Edited September 22, 2021 by Keyo Quote Share this post Link to post Share on other sites
Tjninny 10 Posted September 22, 2021 The only problem with the silver bolt (if it’s the same dimensions) is that the point is to help locating the bolt in the body - the silver one would be slightly more difficult. Quote Share this post Link to post Share on other sites
seanl82 23 Posted September 22, 2021 As far as the rear beam is concerned, I wouldn't worry provided it's the same diameter head and tensile strength. You don't need to remove them completely at any point (other than removing the brackets as you are now), so when you put them back in, just do it with the axle removed from the bracket. That way there is no weight on it so they'll go in no bother at all. 👍 Quote Share this post Link to post Share on other sites
Keyo 47 Posted September 22, 2021 (edited) On 9/22/2021 at 6:37 PM, seanl82 said: As far as the rear beam is concerned, I wouldn't worry provided it's the same diameter head and tensile strength. You don't need to remove them completely at any point (other than removing the brackets as you are now), so when you put them back in, just do it with the axle removed from the bracket. That way there is no weight on it so they'll go in no bother at all. 👍 Thanks mate - I can see they are described as a subframe bolt so have no concern of the swl on the bolt- for £6.00 for x 6 I might as well buy them and share the out come. Edited September 22, 2021 by Keyo Quote Share this post Link to post Share on other sites
ChrisL 20 Posted November 10, 2021 Hi, not sure if you got sorted but these bolts are available through ECS tuning in the states. I’ve just bought the 6 I need for my rebuild. they say genuine VW parts. Quote Share this post Link to post Share on other sites
Keyo 47 Posted April 25, 2022 Just to finish this thread these bolts worked fine and are described as beam carrier so correct loading. Quote Share this post Link to post Share on other sites
_Matt_ 32 Posted April 25, 2022 Thanks, just purchased enough for my cars. Quote Share this post Link to post Share on other sites
