Dox 31 Posted July 11, 2022 Green storm about to meet its maker. leather steering wheel £100 boot carpet set £50 cream interior plastics from £10 each solitudes £60 sunroof (guidance needed with price please) black dashboard £50 tail lights 4 pieces £50 shout up if you’re looking for anything before the shell goes (she’ll cuts etc). collection from Crewe 10 mins j16 m6 Quote Share this post Link to post Share on other sites
Dox 31 Posted July 11, 2022 Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted July 11, 2022 What’s the condition of the a pillar trims, any scars? Quote Share this post Link to post Share on other sites
Dox 31 Posted July 12, 2022 What’s the condition of the a pillar trims, any scars?Passenger has a small screw hole for ultrasonic for the alarmSent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Dox 31 Posted July 12, 2022 Passenger has a small screw hole for ultrasonic for the alarmSent from my iPhone using TapatalkJust noticed edge cut on passenger sideSent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Keyo 49 Posted July 12, 2022 Its takes a long time to wire the rear glass out but the one side is very obsolete- worth disk cutting the glass out with the frame surround. The rubber perimeter seal is also very obsolete right now and should pull out. Pull handle on a pillar has x2 special speed nuts pull them out. Tailgate push rod plastic buffer plate is extremely obsolete and rare - need to squeeze with pliers under it to remove without damage. Also the tailgate loading trim is very rare. Quote Share this post Link to post Share on other sites
Dox 31 Posted July 12, 2022 Roof lining, the covering fell off, suitable for recovering £30Heated seat loom, I have the relays too £50Airbox and k and n panel filter. £150Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Dox 31 Posted July 12, 2022 35 minutes ago, Keyo said: Its takes a long time to wire the rear glass out but the one side is very obsolete- worth disk cutting the glass out with the frame surround. The rubber perimeter seal is also very obsolete right now and should pull out. Pull handle on a pillar has x2 special speed nuts pull them out. Tailgate push rod plastic buffer plate is extremely obsolete and rare - need to squeeze with pliers under it to remove without damage. Also the tailgate loading trim is very rare. I think the best way to get the glass is to angle grind the shell seam and b pillar, then dissect the seam piece by piece to get the glass and seal intact. A couple of hours work tho and no guarantees you’ll get the glass intact…. Quote Share this post Link to post Share on other sites
Dox 31 Posted July 12, 2022 Passenger sideDrivers sideSlides tooSent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Keyo 49 Posted July 12, 2022 2 hours ago, Dox said: I think the best way to get the glass is to angle grind the shell seam and b pillar, then dissect the seam piece by piece to get the glass and seal intact. A couple of hours work tho and no guarantees you’ll get the glass intact…. I just used a scaffolder Stihl cutter and cut 2 inch outside of metal.- brutal I know but glass is there if someone wants to wire it out 😂 Quote Share this post Link to post Share on other sites
Dox 31 Posted July 12, 2022 19 minutes ago, Keyo said: I just used a scaffolder Stihl cutter and cut 2 inch outside of metal.- brutal I know but glass is there if someone wants to wire it out 😂 So what are they worth? im making little progress today tbh…. It’s fighting me Quote Share this post Link to post Share on other sites
Keyo 49 Posted July 12, 2022 (edited) 5 hours ago, Dox said: So what are they worth? im making little progress today tbh…. It’s fighting me Good question to me they are worth keeping spare - for example glass a windscreen now sells in the USA for 1000 dollars as obsolete - although there is one guy bringing them in a bit cheaper now from Europe. They get damaged through removal - seals perish - break inns - debris damage. What is the obsolete side worth to someone who needs one- depends how cruel you decide to be lol- certainly an essential spare now - folks dont realise yet about these rear windows- shaun managed to get one new one for his rado but the other one is a no go. This is how much they are new for the one side. https://www.mecatechnic.com/en-GB/custode-arriere-gauche-teintee-vert-pour-vw-corrado_C184594.htm They are on ebay for 150 used- if you was local i would lend you my petrol disc cutter - same type you see pavers use but with a metal blade- i also chopped out the rear vw badge plate on the tailgate - plus the whole drain panel under the windscreen. Turrets as well are a good cut- also whole filler cap on rear panel area Edited July 12, 2022 by Keyo Quote Share this post Link to post Share on other sites
Dox 31 Posted July 12, 2022 I already have a full rear panel, filler cut, both rear arches from Hennys old g60 i have a 9 inch grinder 😂 Front inner wings up to the turrets have already gone to a member here is £50 about right for an engine top cover? Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted July 13, 2022 16 hours ago, Dox said: Passenger has a small screw hole for ultrasonic for the alarm Sent from my iPhone using Tapatalk Mine have the little screw holes too. Never mind 😖 Quote Share this post Link to post Share on other sites
Dox 31 Posted July 13, 2022 2 pairs of 288mm carriers £22 each postedOne pair of 312 £30 postedSent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Dox 31 Posted July 13, 2022 B pillars as requested, as removed need a cleanSent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Dox 31 Posted July 20, 2022 Heated seat loom sold one pair of 288mm carriers sold sunroof pending as are A and B pillars Quote Share this post Link to post Share on other sites
Cressa 46 Posted July 22, 2022 Dox, do you have the female plug (socket) for the two front fogs still on the car? I am after 2 if you can help me with this 👍 Quote Share this post Link to post Share on other sites
Dox 31 Posted July 22, 2022 31 minutes ago, Cressa said: Dox, do you have the female plug (socket) for the two front fogs still on the car? I am after 2 if you can help me with this 👍 I have somewhere, I don't know what they look like (2 years since I removed the fogs) and don't really want to cut looms ATM. Who drive Corrados in fog anyway lol (we should all sell them and book a cruise with the proceeds?) No offence meant Quote Share this post Link to post Share on other sites
Cressa 46 Posted July 25, 2022 On 7/22/2022 at 10:45 AM, Dox said: I have somewhere, I don't know what they look like (2 years since I removed the fogs) and don't really want to cut looms ATM. Who drive Corrados in fog anyway lol (we should all sell them and book a cruise with the proceeds?) No offence meant 🤣🤣 no one in a corrado agreed. They were to go into a mk2 golf loom I am making. Something else that will probably never see fog either Quote Share this post Link to post Share on other sites
Dox 31 Posted July 29, 2022 Front windscreen, a pillars and roof to the sunroof aperture, little rust on show£100 OnoSent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
