ger040
vr6 starter motor
as above looking for a vr6 starter motor - ends with part number H (manual car)
Must be willing to post to belfast - thanks
Do you have the full part# ? You might still be able to get a new Bosch unit - if it's used you're after, there's plenty on eBay or try the Corrado facebook groups.
I haven't had any experience of it, but it's claimed that a Golf 5 V5 one will fit with some minor work, or is even a direct replacement, although that would be too easy.
Edited by fendervg
11 minutes ago, fendervg said:
https://www.autodoc.co.uk/bosch/1157162
Any use? Seems a good price too - I'd stay away from the other cheap Chinese copies on there ("Ridex", anyone?) the names are pretty hilarious.
Thanks for the reply - to be honest its for a car that i dont know if its worth saving (almost 200k) - just want something to get it moving again
Fitted a battery only to hear a series of clicks
Bloody hell there is some amount of crap on ebay
I think ridex is auto docs own brand ?? - seems to be everywhere on its site
Ah ok - could be corrosion on the starter connections or a shot solenoid - will it jump start?  Ignition switch could also be faulty.
8 hours ago, Dox said:
Does the engine turn with a socket on the crank?
Yes one of the first things i done
I have removed the starter will call to a local auto spark to test it
Ignition switch - forgot about that one !
When you move it to start to you hear the starter solenoid click? If not, it's prob seized but can be easily sorted once you remove it
Edit: sorry, noticed you've already removed it. Try applying power direct to the solenoid
Edited by fla
Got a starter off a '92 corrado that's only got 19.000km's..
Crashed car in late '92 so was only not even a year old.
Let me know if your interested mate.
Cheers.
Cheers.
sent you a PM thanks
