Andy D 0 Posted November 18, 2004 Hi ya I was diving along the other day and my engine cut out. After getting the car home I found that my crank pulley had come off and sheered the bolt in side the crank. What i wanted to know is the crank on a g60 the same as a normal 8v injection engine or is it reinforces and does anyone have a part number? Quote Share this post Link to post Share on other sites
h100vw 0 Posted November 18, 2004 It is the same as a std Golf and 16v. If the bolt has snapped off, you can probably get it out with an easiout. With the tension removed they are often pretty slack. Or try drilling two small holes and using some pointed pliers? They sometimes damage the slot for teh woodruf key, I have seen these welded back up with the crank in situ. I have a crank in my garage, Brand new VW one. I would consider selling it, if you want it let me know. Gavin Quote Share this post Link to post Share on other sites
Banana Man 0 Posted November 18, 2004 Have you taken the head off yet? When the pulley bolts shears it usually damages a couple of the valves, when mine went last year it bent 2 exhaust valves and it also damaged the groove in the crank so I had to replace that as well. As Gavin says the sheared bolt is usually easy enoungh to get out as it is no longer under tension mine just wound out using my finger! When you put another crank in use a DX engine code bolt from a golf for the pulley it isn't a stretch bolt and is alot stronger than the PG bolt. Quote Share this post Link to post Share on other sites
h100vw 0 Posted November 18, 2004 And don't forget the big washer that goes under the DX bolt. Gavin Quote Share this post Link to post Share on other sites
Henny 0 Posted November 18, 2004 yup, I'll echo what both of the above say... I had mine snap too, took 2 valves with it and that was at just over idle... Don't forget to threadlock the DX bolt if you use one! ;) 8) Quote Share this post Link to post Share on other sites
Rossco 0 Posted November 18, 2004 Right can someone put up part numbers for the bolt and the washer cos ive been scanning etka and cant find it at alll, ive got a brand new corrado one but with all these horror stories i really want a golf one, cheers guys Quote Share this post Link to post Share on other sites
Henny 0 Posted November 18, 2004 they're on here somewhere... do a search for "bolt AND number" and you'll find it... 8) *edit* It's at the end of the first page HERE Quote Share this post Link to post Share on other sites
Rossco 0 Posted November 18, 2004 Cheers man but no part no for the washer, any ideas?? Quote Share this post Link to post Share on other sites
scottgroovez 0 Posted November 18, 2004 Non-stretch Crankshaft Pulley Bolt - N 040 106 4 - (VAG) (threadlock it) Non-stretch Crankshaft Pulley Bolt Washer - 068 105 193 A - (VAG) Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 18, 2004 The replacement non stretch bolt on ETKA looks the same as the old one, ie its shouldered with no washer. Quote Share this post Link to post Share on other sites
Andy D 0 Posted November 19, 2004 cheers for your help lads. I havent got aound to removing the head yet but i expect there to be some bent valves. Luckly i am a mechanic so i'll be able to do the work myself still its going to be expensive. H100 i've emailed you i am intrested. Quote Share this post Link to post Share on other sites
