coullstar
ET 42 ok?
I am looking at a set of wheels 7x16 with an ETof 42. They are off a Vauxhall.
Has anyone run this size offset on thier car? I was thinking that the wheels might actually hit the shocks. I realise that it is easy enough to get spacers but it would be good to know anyhow.
What is the centrebore on the Vauxhalls? I think they were on a Corsa.
Off the top of my head its 56.6 but i'll check the guide when i'm back in the office.
even if they don't rub the shocks i'd want spacers on coz they'll sit too far in :|
hutchy
That's the standard VR6 offset, so they should go on OK without hitting the struts. They might rub on the inner arch on full lock a touch though. Stick some 5mm spacers on to be safe.
If the Vauxhall CB is larger, you'll need some plastic spiggot rings, but VW CB is 57.1mm normally.
They do have a wider track but they compensate for that buy making the offset deeper. It's worth a go without spacers just to see what happens!
You should be able to get Centre bores bored out in a machine shop, you're only talking a mill or so, so won't affect it's structural integrity. Just depends how much you like these wheels I guess.
The centre bores definitely 56.6 so it'll need to be bored out to 57.1.
if your any where near manchester or bolton i can put you intouch with a place that'll do it for you mate.
hutchy.
my leggeras were ET35 and sat in too far for my liking too. the TTs are ET32 and perfect but scrub on the back.
cant bloody win :(
