Southernwood
steering rack pipes
The steering rack pipes on my car are rotten and have burst, does anyone do replacement pipes, I have tried VAG but they say you can only buy them with a Rack! Does anyone know of anywhere that does them or should I try somewhere like pirtek to try and make some up from the old pattern?
Passat hoses are virtually identical to the corrado ones, equivalent year needed.
I got a virtually new looking pump-to-rack pipe for about 25 quid from Volks-Apart in London for my 1990 16v.
David.
When I had mine replaced (for it's MOT) VW quoted me silly money for pipes (about £180 I think?) so the garage removed them for me and I had some made for about £45 I think, good quality too, the garage had trouble getting one of the ends over the connector (reservoir?) though because the metal braid in the hose made it less flexible. :roll:
The connectors used are the expensive bit apparently, they aren't commonly used in the industry.
Good luck
It's actually the pipes on the rack and not the pump/reservoir ones I mean. Cheers guys.
Your local branch of "Pirtek" will make some new pipes for you - check the yellow pages.
We used them a few times when I used to work for Mercedes
Given that VR6s have completely different steering racks from the earlier models, I very much doubt it.
