kerrinmay 0 Posted December 21, 2004 My central locking works fine when using the remote outside the car, i.e. all locks activate, however when sitting in the car and pressing the door lock pin down, it only operates that individual door. Shouldn't it activate the whole system? Any ideas what might be wrong? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted December 21, 2004 Does the CL work by pressing the knob then? Never tried it. I always assumed you had to use the alarm or key as the switches that trigger the CL pump are in the handle. Quote Share this post Link to post Share on other sites
kerrinmay 0 Posted December 21, 2004 Oh ok. Maybe I'm just expecting it to do something it doesn't! Guess I'm just used to other cars where you can press the door pins down and it activates the whole lot. Kind of handy though if you are driving slowly through a bad neighbourhood! Quote Share this post Link to post Share on other sites
dr_mat 0 Posted December 21, 2004 My C used to trigger the central locking when you push the driver's door pin down, but it doesn't any more since I had the handle replaced. I couldn't be arsed to get the garage to fix it, on the basis that they fecked up the window mechanism first time they looked at it so I'd rather they just left it alone!! Quote Share this post Link to post Share on other sites
Jim 2 Posted December 21, 2004 Pretty sure on my old 2.0 16v that pressing the drivers side door pin down locked the doors, but the passenger one didnt.. or vice versa. I don't remeber the specifics but I am certain this was discussed on the eGroup some years ago :) Quote Share this post Link to post Share on other sites
oxfordpaul 0 Posted December 21, 2004 On mine the drivers door activates the c/locking but the passenger knob just does that door... Quote Share this post Link to post Share on other sites
kerrinmay 0 Posted December 21, 2004 That's sort of what I'd expect. Just thinking though, and I actually have a different key for the driver's door, so chances are that when the driver's door lock was replaced by a previous owner, it wasn't set-up right. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted December 21, 2004 Yeah, just checked mine and it does activate the CL by pressing the driver's knob. Never knew that....and I've had the car 2 years :roll: :lol: You need to investigate the actuator and / or the handle on the driver's side unfortunately. Not a nice proposition at this time of year :? Quote Share this post Link to post Share on other sites
Timo. 0 Posted December 21, 2004 Mine doesn't do that!!! :cry: :cry: Always thought it should though, but I'd rather not mess with it incase it all goes pear shaped!! T. Quote Share this post Link to post Share on other sites
BeavisJem 0 Posted December 21, 2004 It should activate the central locking only if the door is shut. Quote Share this post Link to post Share on other sites
bcstudent 0 Posted December 21, 2004 Mine does precisely squat Quote Share this post Link to post Share on other sites
Rossco 0 Posted December 22, 2004 Aye mine too but brians(dubster82) one locks everything from the inside, weird??? Quote Share this post Link to post Share on other sites
kongo127 0 Posted December 22, 2004 On mine the drivers door activates the c/locking but the passenger knob just does that door...Just like mine! 8) Quote Share this post Link to post Share on other sites
Tekara 0 Posted December 22, 2004 My old VR used to lock all doors when you press the drivers door pin, new one however does not do this. One of the silly little things i can be bothered with at the moment, but if there is a quick fix ill try it out. BTW CL works either by turning the key in the door or remote. Quote Share this post Link to post Share on other sites
Riley 0 Posted May 19, 2007 Thread ressurection :!: Does everyone else have an unconnected plug in their drivers door? Anything to do with the door pin activating the central locking? :? And on the vac operated pump,there is a leccy connection for a plug! Wonder what happens if you plug it in :?: Edit:Just to add,i did have a poke about with a 12v tester a while ago...and the plugs wiring is something to do with the central locking for definate...Im guessing that the connection on the actuator...will just complete a circuit (one live into the connection,then coming out) when the pin is pushed down. It be a mechanical switch rather than electrical... Anyone want to go try it? :!: Quote Share this post Link to post Share on other sites
