pablo_vr6 0 Posted December 28, 2004 EDIT: was the ignition barrel transponder receiver. £25 from VAG hey all - have had an intermittent problem on my vr6 for a few months now. every so often when starting the car would fire up but about 1 second later die. starting and holding a rev of around 4k for a few secs has always solved this. today however the same thing happened but it wont run at all for more than 1-2 secs. we have: disconnected batt for 30 mins to let it settle checked fuel pressure at the rail (OK) pulled the MAF sensor off (same thing but ran rougher for that one second) usual arm/disarm the alarm (cobra cat1) now when the problem has occurred before its always been on starting never while driving or idling. any suggestions for things I can check would be appreciated. Will try to get vagcom tomorrow (expect a PM mike!!) If we cant DIY it I am going to fling myself to the mercy of an auto spark but thats gonna mean no car till the new year. help pls :) -pablo Quote Share this post Link to post Share on other sites
joebloggsVR69 0 Posted December 28, 2004 Sounds like what I had - a dodgy transponder in your key perhaps Have you got a spare key? Try it with that, see if it starts Quote Share this post Link to post Share on other sites
Andi 2,147,483,647 Posted December 28, 2004 Check that its not something different now. You may be wrong assuming its the same problem you were having previously. Check all vacuum hoses for splits - including the plastic box to the back of the engine that has 2 hoses running into it. If the VR6 engine can't keep the vacuum, it'll just die. Might help - happened to me! Quote Share this post Link to post Share on other sites
pablo_vr6 0 Posted December 28, 2004 Sounds like what I had - a dodgy transponder in your key perhaps Have you got a spare key? Try it with that, see if it starts dont have a spare key :( the key I have is solid so not sure if there is anything inside it. Check that its not something different now. You may be wrong assuming its the same problem you were having previously. Check all vacuum hoses for splits - including the plastic box to the back of the engine that has 2 hoses running into it. If the VR6 engine can't keep the vacuum, it'll just die. Might help - happened to me! 99% sure its the same problem mate. will try around the hoses etc but my gut is telling me electrical. how long does it typically run before dying with a vacuum problem? thanks for the replies so far lads. Quote Share this post Link to post Share on other sites
Andi 2,147,483,647 Posted December 28, 2004 My vacuum prob I got 2secs out the car the died - irrelevant of throttle. I take it you're getting a spark? Quote Share this post Link to post Share on other sites
pablo_vr6 0 Posted December 28, 2004 seems to be yeah. was dark and cold tho - will get it to the garage tomorrow and get a proper look around. Quote Share this post Link to post Share on other sites
fla 9 Posted December 28, 2004 Have you got VAGCOM - check the sensors. I had a similar problem and turned out to be the TPS. Also check your camshaft position sensor and relay 109. Quote Share this post Link to post Share on other sites
pablo_vr6 0 Posted December 29, 2004 what does relay 109 do? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted December 29, 2004 I think 109 is the fuel pump or ECU relay? Quote Share this post Link to post Share on other sites
pablo_vr6 0 Posted December 29, 2004 fuel pump is defo ok as the rail is getting plenty of pressure. Ill check the relays etc down around the fusebox and all fuses. has to be something that only affects starting tho as anytime Ive had the problem before was on starting - never while running. Bad time for it to happen too - nowhere will be open till new yr :( Quote Share this post Link to post Share on other sites
pablo_vr6 0 Posted December 29, 2004 update: vagcom says the car was blocked from starting by the immobiliser. so I guess either the key or the coil is dead. I only have one key so cant test that end. whats my next step now lads? cheers for the info so far! -pablo Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted December 29, 2004 Ah yes, keep forgetting you've got a late one. You should be able to get another key from the dealers? Best solution is to remove the VW immobiliser and fit a better one, but that's not a quick solution unfortunately! Quote Share this post Link to post Share on other sites
pablo_vr6 0 Posted December 29, 2004 kev: picked up a new coil from the dealer so will be fitting that this evening. new key may be a little harder/more expensive to sort. wont be any bigger work going on as the car wont be in my possession much longer. time to change in the new yr once I can get a decent price for it. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted December 29, 2004 Moving onto the S3 already then? Quote Share this post Link to post Share on other sites
pablo_vr6 0 Posted December 29, 2004 nah no S3 just yet ;) need the cash for wedding in June. then its S3 time while she is still in a good mood :D Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted December 29, 2004 LOL...yeah, get it in quick before she gets too involved in your finances :) Quote Share this post Link to post Share on other sites
pablo_vr6 0 Posted December 29, 2004 thats it Kev - need to start with a web of lies and deciet to get what I want before the regime is imposed :D back on the subject of keys tho - does it cost much to get one done? Im assuming its not too bad if the main key is ok but if its knackered am I in big do do? Quote Share this post Link to post Share on other sites
joebloggsVR69 0 Posted December 29, 2004 My VW dealer told me it would cost about £40 to get the key re-coded (Apparently they've got to get the codes from Milton Keynes head office, and they expire after 24 hours??!?! :roll: ) But you mentioned your key was solid? If it's got a transponder in it, I'm pretty sure you should be able to prise the key apart - I can with mine anyway.. :? Quote Share this post Link to post Share on other sites
pablo_vr6 0 Posted December 29, 2004 well its solid in that there are no bottons etc on it but there is a join around the edges so it would split in two pieces. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted December 29, 2004 Yeah there's just a little bit of metal in there! Some C keys had a light aswell as the immobiliser inductor. Quote Share this post Link to post Share on other sites
pablo_vr6 0 Posted December 29, 2004 fixed WOOHOO - transponder receiver. £25 from vag. had terrible nightmares of £100s :( Quote Share this post Link to post Share on other sites
dr_mat 0 Posted December 30, 2004 You mean you're over the moon about paying 25 notes for a coil of fine wire and a small plastic housing? ;) Quote Share this post Link to post Share on other sites
pablo_vr6 0 Posted December 30, 2004 YUP!!!! I had envisioned hundreds!!!! Quote Share this post Link to post Share on other sites
