julianhh 0 Posted January 21, 2005 Hi, I am new to corrados! Any ideas about this please? Plus my revs seem to stick or hand before dropping - is it the ISV? Ta very much Julian Quote Share this post Link to post Share on other sites
ben16v 0 Posted January 21, 2005 hello and welcome. just replace it mate, not a big job AFAIK what engine? 1.8 16v revs tend to drop quite slowly. Quote Share this post Link to post Share on other sites
G60Jet 1 Posted January 21, 2005 replace the cable and rubber gromit that goes into the pedal if the the pedal is stiff the gromit stretches and the cable will pop out all the time Quote Share this post Link to post Share on other sites
Furkz 0 Posted January 22, 2005 why not try WD40 on it 1st to see if it loosens it up a bit,,,, jus a thought Quote Share this post Link to post Share on other sites
VR6 0 Posted January 22, 2005 Don't use WD40. It's not a lubricant! Just replace it. Quote Share this post Link to post Share on other sites
RadoAds 0 Posted January 22, 2005 for what they cost just replace it, but like someone said earlier you could try a bit of oil down the sheath of the cable to free it up just to see if that is your prob, WD would free the cable up but it wouldnt solve your problem for long as like someone said earlier its not a lubricant, you could try some chain wax for motorcycles if you know anyone whos in to bikes that stuff has a million and one uses Quote Share this post Link to post Share on other sites
Gman 0 Posted January 23, 2005 I have the same problem with mine. Pls let me know when you get it sorted Quote Share this post Link to post Share on other sites
Skimask 0 Posted January 23, 2005 If its stiff, the chances are the inner cable has broken a couple of strands which are catching on the sheath. Lubricating it won't help as it'll break anyway. Better to replace it, much cheaper than calling out a breakdown lorry. Quote Share this post Link to post Share on other sites
julianhh 0 Posted January 23, 2005 Thanks for the replies, I guess a VW main dealer part only? Ta J Quote Share this post Link to post Share on other sites
W3RKD 0 Posted January 23, 2005 only around £17 for a new throttle cable Quote Share this post Link to post Share on other sites
Henny 0 Posted January 24, 2005 don't forget to buy the rubber grommet that goes into the throttle pedal though! If you throttle has become stiff, this will have knackered the grommet and your cable could become disconnected from the pedal while you're driving.... :| (yes, that's the bitter sound of a voice of experience.... :oops: ) Quote Share this post Link to post Share on other sites
stu h 0 Posted January 24, 2005 agree with what has been said; definately replace the cable. has this on my 16v, i hadn't noticed how stiff it had become. got the whole cable replaced for about £35 inc parts. the old one had started to come apart inside, and was catching - in a pretty poor state Quote Share this post Link to post Share on other sites
julianhh 0 Posted January 24, 2005 thanks people. J Quote Share this post Link to post Share on other sites
