pablo_vr6
Rear shocks
does the C share rear shocks with any other car?
Mine is making a noise from the back and I can get a lend of a mk2golf shock to test as I dont want to buy a new one and that not be it.
cheers
took the whole shock out the other day. top plate was fine, mounts were all fine.
what else would cause a knocking back there? only really on low speeds and only takes the slightest bump to make it knock.
really stumped.
Could still be the exhaust!
You need to get under and look how close it is, maybe even zip tie a bit of hose to your axle to rule that one out.
Then I would try a diff shox, but failing that it will be your rear axle bushes.
Went through this with my golf.
are the bushes a bastid to change? Im imagining they will be.
good tip on the pipe/exhaust - will try it out. The exhaust was in to get the cat fitted back on so may have been hung differently.
might be worth getting new rubber hangers for the exhaust anyway.
does the rear of the car ever feel odd while cornering or at speed?
Old worn shocks can clunk, particularly when cold. They go a bit dry, and it never goes away unless you swap 'em. That said, they're not expensive, and frankly if the car's done more than 50,000 miles on 'em you will significantly notice the difference when you replace them!
In fact, GSF sell SACHS/BOGE gas rears (OE for the VR6) for about £30 each.
