mistrall
loud ticking sound? (fixed-open snifer pipe-lol)
Comes from the exhaust manifold so you can monitor emissions from under the bonnet without sticking the probe in the exhast pipe.
Gvain
and you can't simply stick a probe up the exhaust on a G60 'cos it's got a Cat which will screw up the readings... hence the sniffer pipe... ;) If you've de-catted the car, you can remove the pipe and simply use a bolt with the correct thread to bung up the hole... (or if you're feeling clever, stick in a second lambda sensor and wire it to a A/F meter! ;) :lol: )
It may interest you all to know that VW actually have this threaded bung for sale its on ETKA right beside the sniffer pipe, i investigated as i was doing away with the cat on my swap and there it is.
Part no.s
Bung bolt - N 016 153 1
Sealing washer - N 013 812 8
Not expensive at all
...they also list the correct lambda sensor in Etka if you look under MKII Golf... ;) 8)
