billinjah 0 Posted February 18, 2005 will they fit? will they fit with spacers? tell me tell me!!! i need those italian stoppers!! Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted February 18, 2005 They will just fit under the 16" Rims - as for the spacers, it depends on the offset and spoke design. Just make sure that if the spacers are anything over 5mm that you get hubcentric spacers, otherwise there just not worth risking the bolts shearing off if you give it too much stick! Quote Share this post Link to post Share on other sites
Henny 0 Posted February 19, 2005 you'll find that anything over 5mm and under 13mm will have to be custom made for you... (I searched everywhere for some! :roll: ) Quote Share this post Link to post Share on other sites
stevemac 0 Posted February 20, 2005 If necessary, get some thicker hub-centric spacers & have them shaved down Quote Share this post Link to post Share on other sites
CoxyLaad 0 Posted February 20, 2005 hubcentric? someone explain? Quote Share this post Link to post Share on other sites
stevemac 0 Posted February 20, 2005 The most central part of each hub sticks out slightly - kind of like a wheel centraliser. Most of the thinner wheel spacers don't have this & this causes the wheels to be centralised by the studs only. Hub-centric spacers have a wheel centraliser (similar to the one on the hub) built into them. Quote Share this post Link to post Share on other sites
