awigman
power steering pump pipe
hi all, got a problem with power steering pump and i apparently need a new high pressure pipe from the p.a.s pump to the rack. i got a quote for £14.1.42 just for pipe, does that sound right to you?
sorry its for a 1.816v 1990
thanks
Can you get the part number? I am breaking a Passat and the pipe may be the same. It'll certainly be less than that.
Gavin
Brand new thats about right mate, there silly expensive things. On another note Gavin i would be most interested if those power steering pipes turn out to be the same as my G60 im pretty sure that they are as it has the same resevoir placement and stuff, let me know by pm if they are the ones and how much you would be after
Most of the Passat ones seem to match with the 16V. The G60 appears to be a bit different. The only one that seems to be the same is the pump to rack pipe.
Harry do you have ETKA? Yes or No being the answers to use. :mrgreen:
I'll sell any of the pipes for a tenner and postage.
Gavin
My extensive research reveals that the pipes on the passat and 16V are the sameish. Reservoir to pump pipe could be the same although the part numbers differ. Passat 357 422 881, 16V 535 422 881
The return to reservoir could be the same. Passat 358 422 891A 16V 192 422 891A
The pump to rack pipe has the same number 192 422 893A
In my experience of VW part numbers, the first 2 digits, 19, 35 or 53 refer to the chassis. 19 being MK2, 35 being Passat and 53 the Corrado. The rest of the number is the part itself.
Harry, looks like they won't help you out I am afraid.
awigman if you want any of the pipes PM me.
Gavin
