potatonet 0 Posted March 14, 2005 021906031 is the part number I came up with, are these actually 30# injectors and can I use them on my G60, or do I have to buy racing injectors? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 14, 2005 Bosch Red Tops are the way to go for tuned G60's Quote Share this post Link to post Share on other sites
RS VR6 0 Posted March 14, 2005 I think the stock VR injectors are like 24lbs. My VF kit came with 30 injectors. Quote Share this post Link to post Share on other sites
h100vw 0 Posted March 14, 2005 Summitracing do 8 30lb injectors for 220 dollars. They are listed as Ford Motorsport, made by Bosch. gavin Quote Share this post Link to post Share on other sites
potatonet 0 Posted March 14, 2005 you are a genius anyone want to go in together with me for 30# injectors, 110 dollars? Quote Share this post Link to post Share on other sites
Rustynuts 0 Posted March 14, 2005 Summitracing do 8 30lb injectors for 220 dollars. They are listed as Ford Motorsport, made by Bosch. gavin Are they a straight swap on a G60 engine? Quote Share this post Link to post Share on other sites
Henny 0 Posted March 14, 2005 yup... they're what are known as "red tops" over here... You'll need an appropriate chip to run the engine with 'em though... ;) Quote Share this post Link to post Share on other sites
potatonet 0 Posted March 15, 2005 Time to REMAP once again, great, maybe I wil just buy a chip anyone got any suggestions? Quote Share this post Link to post Share on other sites
Henny 0 Posted March 15, 2005 Speak to SNS over there... They'll almost certainly have an "off the shelf" chip to suit the mods you've done which will improve matters somewhat significantly! 8) Quote Share this post Link to post Share on other sites
potatonet 0 Posted March 16, 2005 improve matters would be to replace vacuum system, oh wait thats happening tomorrow, YAY! Quote Share this post Link to post Share on other sites
Baz2004 0 Posted March 16, 2005 Would these 30 injectors be a straight swap in the 16V? Quote Share this post Link to post Share on other sites
Henny 0 Posted March 16, 2005 nope... 16V injectors are mechanical, not electronic... You need to modify the inlet manifold and replace the injection system to run 'em on a valver... :| Quote Share this post Link to post Share on other sites
Neverite 0 Posted March 16, 2005 typical... :roll: Quote Share this post Link to post Share on other sites
h100vw 0 Posted March 16, 2005 Would these 30 injectors be a straight swap in the 16V? You could probably screw the inserts from a digifant 8V into the manifold and they would fit then. Next you would need to invent a fuel rail and install an ECU capable of running them. No small task really. gavin Quote Share this post Link to post Share on other sites
