potatonet
steering rack
ok being that no one looks at the other sections for posting very often, IE steering.... I thought I would pose the question here.
I have a 90 G60 US SPEC and am wondering if a 93 canadian spec VR6 corrado steering rack will work in my car. easy quesiton. thanks guys
Doesn't work like that I'm afraid. Moving to Drivetrain.
I know where you're coming from, but you will find that most people use the 'view posts since last visit' feature or most recent posts via the portal.
Sorry about that, but we can't make exceptions, so I hope you can appreciate where we're coming from.
ya i do but does the setup work for my car?
don't think it does.............different part no's between G60 and VR6 ones......not much help to ya but i know the Golf VR6 rack is interchangeable with the VR6 Corrado's one
Corrado VR6 got the Golf 3 GTi/VR front "plus" steering/suspension. The earlier Corrados used the Golf 2 setup...
great so a golf 2 rack would work, like one from a 90
don't think so, there are loads of different part numbers for racks and I think most of the golfs will have different ratio's to the Corrado, don't think any of the passats have the same ones either, you need to make sure you have the same suffix letter(s) on the part number as yours.
David.
A LHD rack for Chassis No. up to 50-N-011 487 uses the same rack as the 16v Golf/Jetta/Vento from 1986 to 1992.
From Chassis No. 50-N-011 488 on it's Corrado-specific.
Me too and ive just ordered a mk2 16v one, its the same, just check etka and put in the part numbers
Watch also the
make of rack,
TRW or ZF?, there may
be differences concerning ratios
between the two.
Also earlier types had 36 Splines
whilst later one's had 22 on the output
shaft.
