Dubbabe80 0 Posted April 20, 2005 Please help :( ! I've got a J reg 1.8 16v which isn't running right at all. Its juddering, the rev counter's bouncing around all over the place, its backfiring & popping. The thing is...it will run ok but then every so often it just starts doing all this and cuts out. This is when it won't start. so far the ignition module, coil and more recently the distributor have been replaced and its still happening! Any ideas?? Quote Share this post Link to post Share on other sites
Walesy 0 Posted April 20, 2005 leads and plugs first i spose??? .....you say it happens every so often...is that when its damp ????? Quote Share this post Link to post Share on other sites
Dubbabe80 0 Posted April 20, 2005 Yeah, the leads and plugs have been done and its not done it when its damp. I've drove to work Monday (8miles) and it was fine then nippe dout at dinner..still ok. then drove home and its started to do it, i've stopped off at the local vw garage but by the time I got there it was ok again so obviously they couldn't do anything. Then on the way home from there its started juddering and popping and this is when its cut out and can't start. So its doing it when its warmed up and its also done it before when I've gone for a run in it! Quote Share this post Link to post Share on other sites
flusted 0 Posted April 20, 2005 Fuel filter? lift pump? Quote Share this post Link to post Share on other sites
Henny 0 Posted April 21, 2005 ignition switch... ;) Quote Share this post Link to post Share on other sites
theRuler 0 Posted April 21, 2005 i've just had the exact same problem on my vr6 it has been cured by securing the plug on the blue coolant sensor. (it was hanging off) Quote Share this post Link to post Share on other sites
Henny 0 Posted April 21, 2005 1.8 16V doesn't have a blue temp coolant sensor... ;) Quote Share this post Link to post Share on other sites
h100vw 0 Posted April 21, 2005 I'd slave in a new ign switch. Only cheap and easy to do. Gavin Quote Share this post Link to post Share on other sites
